Question about Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel
We have a gas maytag gas wall oven that is getting f3 and f5 error codes
  • yadayada
    yadayada May 11, 2010
    go to repairclinic for look up
  • Anonymous Mar 23, 2014
    I replaced the oven temp sensor and ignitor. now I still get f3 and f5 codes. Do I need a new control board.
  • 6,784 Answers
F3
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
F5
Watchdog and hardware conflict
Replace clock (ERC).
Posted on Jul 18, 2009
2 Suggested Answers
  • 794 Answers
SOURCE: My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 04, 2011
Oven has a f3 error
Hi angelice_wil,
The F3 fault code description is a shorted or open oven temperature sensor. The easiest way to correct this error is to check the sensor harness and harness connection between oven sensor and oven control. If you noticed that the wiring is all ok, replace the oven temperature sensor (RTD).
Hope it helps.
Apr 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
F3 and F5 errors when first trying to start oven or in the middle of cooking will also get them Mostly F3
F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC).
Aug 12, 2010 | Maytag CWG3100A Gas Single Oven
Maytag 24 " wall oven gas trouble code F5
Hi ngwhite,
The trouble code F5 is a Watchdog and hardware conflict. You need to replace the clock (ERC).
Hope it helps.
Aug 02, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
Feb 04, 2010 | Maytag CWG3100A Gas Single Oven
Hi sorianocynth,
Hope this helps.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
Maytag model CWG3100AAB error code f3
when the clock goes off on my oven the oven stopsand will only come back on when it is cooled off.
Jan 18, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Feb 24, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F3 and F5 errors that shut off oven
F3 *Open Temperature Sensor Controller not receiving data from temperature sensor.
F5 *Control Output Disabled No control output.
Sorry you will have to replace oven sensor and oven control...
May 22, 2008 | Maytag CWG3100A Gas Single Oven
Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
521 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
