Question about Mtd Garden
Reattach mower deck spring instruction
Re attach mower deck spring instruction
I have a 13.5 Yardman, MTD I can figure out how to reattach the deck springs? please help.
Posted on Jul 18, 2009
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
Replacing a mower brake tension spring
Mower Brake Return Spring Replacement - Craftsman ...
? 2:15
www.youtube.com/watch?v=kyuE5NBR5xU
Jul 31, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing abrake return spring on Craftsman riding lawn ...
Oct 27, 2015 | Craftsman Garden
Clutch cable routing for a craftsman 971289010 lawnmower
The PTO cable will come out the chassis straight down from the engagement lever on the right side of the dash panel. Will be fastened to the frame on the right side in front of the rear wheel with a zip tie. Loop over the brake rod and attach to the deck on a tab at the rear center of the deck. A hair pin will secure it there. The inner cable continues from there under the belt and the spring hooks into the engagement bracket. There may be two hole for the spring to hook into. They are marked 38 or 42.
Sep 02, 2014 | Craftsman Garden
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replacement of v belt
Instructions1 Place the riding mower on a level surface and set the emergency brake. Open the engine or tilt the seat back to gain access to the battery. Disconnect the negative battery cable with a socket. Turn off the main fuel petcock valve from the tank to the carburetor. Set the attachment clutch in the "Disengage" position. Set the motion control lever to neutral. Place the mower deck lift lever in its lowest position to drop the deck.
2 Pull the belt against the engine drive pulley, then pull upward on it and slip it off the pulley. Unclasp the small clutch retainer spring from the pulley bolt. Detach the big retaining spring and then slide the collar sleeve off. Shove the housing guide out from the br
3 Pull the retainer springs off that hold the rear suspension arms to the rear mower deck bracket. Disconnect the front link arms that hold the front of the mower deck to the chassis. Pull the lift lever to put the suspension arms at full height.
4 Slide the mower deck out from the bottom of the tractor. Tilt the mower deck and prop it up with wood blocks. Use a stiff cleaning brush to remove all mud, twigs and grass clumps. Wipe the top of the deck and undercarriage with a rag.
5 Un-thread the belt from around the idler and mandrel pulley. Place the new belt around the mandrel pulley and idler pulley first, then stretch it up to the drive pulley and loop it into the pulley grooves. Make sure the V part of the belt rests inside the pulley.
6 Use the lever to raise the suspension arms on the deck. Push the deck back under the tractor. Lower the suspension arms and replace all the retaining springs in reverse or the order in which you removed them. Slide the sleeve back into position and secure it with the spring. Reattach the spring to the anti-sway bar. Shove the housing guide back into its bracket.
7 Raise the mower deck with the lever. Reconnect the negative battery cable with a socket. Turn on the fuel petcock valve. Start the engine and engage the main drive lever. Test-drive.
THanks
Apr 02, 2012 | Vacuums
Found large spring at end of cable unattached lying on top of deck cover. Where does the spring attach in order to engage the blades on the riding mower? The lever is very loose and when checking, I found...
There are 4 pulleys on your deck. Two for the blades, these are the big ones on the outsides. To the insides there are two, one on left side is an idler and the one on the right is a tenioning pulley that hooks to the blade engage lever throught the cable you found. Look on top of this pulley and see if it has a piece sticking up. If so the spring at the end of the cable attaches here. Slide it over. You also need to find the clip that goes through the little hole in the end that keeps it from sliding off. Make sure that the cable is properly routed and attached near the back of the deck. If it is still attached, good, if not you will have to find that pin also.
If this is helpful, please rate.
Jul 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Removed mower deck with no problems. Cannot re-attach. Do you have a step by step instruction for this process?
1. Raise attatchment lift lever to its highest position
2. Slide the mower deck under the tractor with deflector shield (grass Chute) to right side of tractor
3. Lower lift lever to its lowest position
4.. Connect the front links to the mower deck and secure with the retainer springs.
5. Connect thye suspension arms to the rear deck brackets and secure with their retainer springs.
6. Connect the anti-sway bar to the chassis bracket and secure with the retainer spring.
7. Push the clutch cable housing guide into the bracket, and slide the collar onto the guide and
secure it with the large retainer spring.
8. Place the flat washer and clutch spring on the idler pulley bolt and secure them with the small
retainer spring.
9. Re-install the blade belt onto the engine pulley it goes on.
Apr 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Spring on deck broke off but can't remember the exact spot to reattach it to. I know of the bottom hook up but not sure where the top goes. help
There are online lawn mower parts sites..and they should have a parts diagram of the deck and where the spring goes...one of the parts sites is www.outdoordistributors.com ..i hope this will help...Keith
Jul 08, 2009 | Garden
Garden Logo
877 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
