Question about Sony Playstation 3 (PS3) Console
PS3 loud fan overheating problem
I have a 40gig playstation 3 that I got in June 2008.Since about April the after about 5 mins of gameplay the fan goes at an outrageous speed an produces a very loud noise which makes it hard to hear the tv and is very annoying.So i decided to look inside the ps3 and took it apart right down to the fan cleaning out all the dust.Then I put it back together and the machine works fine but the fan is still way too loud.Its been about a week now since I took it apart and its still loud as hell so I just wanted to know if you knew any way to fix this problem without sending it back to Sony and having to pay an outrageous sum of money for them to fix it???
  • yadayada
    yadayada Apr 05, 2017
    Fix it or replace it your choice.
FFPro
  • 66 Answers
SOURCE: playstation 3 crazy fan problem
Its a power supply issue you might want to exchange the PS3 for a new 1 at www.sony.com
Rate my Solution Please
I tried my best.
Posted on Apr 30, 2008
  • 207 Answers
SOURCE: PS3 Yellow flash then blinking red
Yes you can but the parts cost is more then sony to fix.. I suggest sell it as broke (if they dont fix it for free) then buy a 40gb at 300$ on ebay!
Posted on May 30, 2008
ripleymojica
  • 643 Answers
SOURCE: Console freezing in main menu after a min green and red dots
do not perform fan test not good for unit. use vacume to clean out unit. if it was the motherboard it wouldnt turn on at all.
Posted on Jun 01, 2009
SOURCE: ps3 shuts off during gameplay
My PS3 shuts off 15 minutes after I play can I fix the problem in system settings
Posted on Jul 06, 2009
SOURCE: playstation 3 overheating Fan problem?
I have done the research!!! And I wrote this guide taking more safety precautions against breaking my system than the originators so this is a reproduced guide wearing safety belts.
This means there are 2 possible problems with your PS3. Either 1) your fan is dying and needs to be replaced or 2) the heat transfer from your 2 processors to the fan is deteriorating. Number 2 is the most popular for overheating because Sony didn't use the greatest of thermal compounds on their processors, and the heat sink solutions Sony used in its launch systems weren't as well engineered as the later systems. 60gig are the most prone.
This has happened to me and I have fixed my PS3. It works perfectly as if I had just bought a new one (fan is super quiet, showing that the heat transfer is working perfectly) and 5 months later I had to repeat the process and it fixed the problem again. So, this solution may have to be an ongoing task through the years, I suggest doing it 3 times a year like I plan on doing. All you need is a couple screwdrivers, thermal paste (preferably something with silver or more expensive, Arctic Silver is good), and a heat gun (usually made for stripping paint) that gets to at least 650F. The processors in this MB are soldered in...
Okay, assuming you are good with handling hardware and get the PS3 bare down to its motherboard, you should see the huge *** fans mounted to the 2 processors, 1 says GPX and the other CELL I think.
1- You need to take off the fan carefully 2- Clean all the dust you can possible see, CAREFULLY 3- Use acetone or some other 99% alcohol compound to clean the old thermal paste off the back of the processors and the mounts of the fan. --------------------------------- This part is important --------------------------------- 4- Look for the 2 black chips that are almost touching each processor above (or below depending on the direction the board is) and pay attention to their location to the chips for when the board is upside down.
5- Place your motherboard on a flat, heat resistant surface and set up to where nothing will touch it for 30 minutes.
6- Using the heat gun, heat the processors for 25 seconds a piece (less time the hotter the gun) using a circular pattern as not to have the heat focused in 1 spot. Then do the same for the 4 black chips.
7- Let the motherboard cool for 30 minutes. You will hear popping noises, this is the solder hardening back up after being set further in its socket. DO NOT TOUCH MOTHERBOARD. It is hot and any outside pressure or contact could snap it. Just let it sit there.
Whats happening is your are resetting any connection damage that might have occurred from the processors getting hot and not cooling properly. This also corrects any minor misalignment of the processor and its seat.
8- Flip the motherboard over and repeat steps 6 and 7.
9- Now apply a thin layer of the thermal paste on the back of each processor. Just enough so you that appears like you can see through it. Not literally but to the point that you think you can make out a letter on the processor.
10- Mount the fan back on carefully and clean up all excess thermal compound that may have been squeezed out the sides.
That should do it. Put the PS3 back together, leave the final screws unscrewed, hold your breath, pray to your deity and turn it on.
Like I said earlier, this happened to me I. I did this fix, failed because I didn't heat the processors long enough. Increased my heating time by 15 seconds each processor, and then my PS3 ran faster, smoother, and quiter for about 5 months before I had to do this fix again because my girlfriend doesn't like to turn my PS3 off (have to shorten auto shutoff to 1 hour now *sigh*). But fixed for a second time with same results.
Good luck gents. This solution does work, but you must also know that it may void the chance of Sony fixing this for you for 150. I paid $7 (US) for the thermal compound and $25 for the heat gun. And the PS3 are $300
Posted on Sep 24, 2009
Ps3 shut down itslef as soom it is on
If you've been playing it a long time it's probably overheated. Give it a few minutes to cool down. There may also be a problem with the fan that is causing it to shut off (which it is programmed to do, lest the system burst into flames after several hours of gameplay).
Jun 28, 2011 | Sony Playstation 3 (PS3) Console
My ps3 keeps freezing during games
Problem: Your Playstation 3 console is freezing during gameplay. There are usually two problems that would cause your Playstation 3 to freeze during
gameplay. I will start with the most common problem:
1. The Blu Ray Laser is wearing out. This is a common issue among the newer video game consoles. The laser is constantly lighting up to read the discs while you are playing your Playstation 3 whether you are playing games, Blu Ray movies, or DVD movies. Eventually the laser will burn out. As it starts to wear out, first the games or movies will freeze. After a while, it will not read Blu Ray at all. Finally it will quit reading anything. You can find lasers at the following website starting at $49.95. The same website also performs repairs of the Playstation 3 console:
http://store.richspsxparts.com/pl3paac.html
2. Overheating. This is less common. If your PS3 freezes and you shut it off and back on and it comes on ok, it's probably not overheating. If heat is the problem, it will freeze right away if you turn it back on right away without giving it time to cool off. If it turns on OK with no problem and doesn't immediately freeze up, the laser is your issue. If you turn it back on and it freezes right away, your PS3 may be overheating.
If your PS3 is overheating, the best thing to do is to make sure you do not keep it in an enclosed area. Playstation 3 systems and XBox 360 systems run very hot. You must keep it in the open so it gets as much cool air as possible! You can also upgrade the fan inside of your Playstation 3 with the Whisper Fan which increases cooling. You can also find it at the following website:
http://store.richspsxparts.com/newpl3ps3taw.html
Apr 19, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turns off randomly after 15 min. in the menu and during gameplay too. no blinking red lights. so it's not overheating. it has proper ventilation. does anyone know how to fix this?
Maybe your PS3's main power supply is damage. try to find a local electronic repair shop or sony service cebter near you and let them take a look.
Jun 08, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is freezing 10 min or so into online, and its getting hot
Freezing means the laser is bad and will need to be replaced in order to fix this problem. You can have this done at any professional game console repair company. If you want, you can check us out at www.wiredextreme.com. You can also contact us at support@wiredextreme.com or 214-222-5788. Hope this helps.
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont stay on
Your PS3 may be overheating. Check the exhaust of the ps3 where the hot air comes out for any excessive dust. If you have a 60GB PS3, you can blow them out by turning off the PS3 by the back switch and then turning it on using the back switch with you finger on the eject button. The PS3 should beep 3 times and your fans should go at full tilt for about 30sec to 1 min.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
Overheating
Go to any store that sells ps3 stuff and buy a ps3 fan I got one for about 35 dallars makes my ps3 run very good
Jul 12, 2009 | Sony PlayStation® 3 (60 GB) Console
Ps3 freezes within 3 mins of gameplay
my p3 will not allow me to play games or blu-ray dvd, it just dirty or damage disk
Jan 14, 2009 | Sony Playstation 3 (PS3) Console
Re: playstation 3 freezing
Update firmware for the ps3 via the sony website or send it in for servicing to sony. It is most likely that the laser has gone bad and thus the discs cannot be read as with alot of the 40gb models
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
1,217 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
