Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
a
armando osorio Posted on Jun 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony flat panel TV.
My Sony LCD TV has a solarize scream. I changed the main board and the T-com board. When I installed these two board, I got the same problem. I notice that beside having a solarize scream I can also see other back ground images. Can it be that I have a bad LCD panel? and if I do have a bad cream panel, how do you test it?
Electro Med Services
Level 3:
  • Sony Master 6,694 Answers
  • Posted on Jun 21, 2016
Sony Master
Level 3:
Answers
6694
Questions
Helped
1871000
Points
21433
The LCD panel is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Testimonial: "I still need to know how to test the LCD panel?"
Sony tv solarized picture fix?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory ResetF (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sony LCD TV.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
How to fix my solarized tv?
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sony Bravia LCD tv color has become negative/solarized
do you mean t-con board? if you changed t-con board and there is no improvement you just have to replace the lcd panel.
Replaced the main board for dead tv she works now but picture looks solarized thought i could go intp factory mode an swotch panel types but cant get into factory mode any ideas???
Check your lvds, connections or the flat cable that goes to your main and tcon that's connected to the panel as well. Take out and clean the cables connections
Sony LCD klv-nx500 solarization picture please help
What is causing solarization?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
2answers
Have a Sony Bravia KDL-40v4100 Flat panel, had a bad storm, lightening strike in front of house, now the tv will not turn on.
Now tv turn on?Front LCD screen panel power light indication flashes or totally dead?Yes,than the power board is dead,that the board where power a/c cord plug into it.Take the tv aparts.That the power supply board,require changing.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
