Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Driver icon for My Book External Drive not detecting usual icon.
When I go into my computer, my book (G) will not detect the usual drive icon. Instead, it just shows that icon, when a format is not recognized. How do I fix this? I looked everywhere within properties and found nothing.
  • 696 Answers
If the format is not recognized it generally means the drive is corrupted or damaged. In either event if you have crucial data on the drive comment back here with your Country, State, City and I will point you in the direction of a pro who can help get your data back.
If it has no important data on the drive you can simply reformat it and continue using it.
The reason you cannot change a setting is , it isn't a setting at fault in most cases. Generally this happens either from disconnecting the drive or powering it down without properly ejecting the drive. The other cause is hardware failure, but except in a few % of cases that won't allow you to see the drive at all in My Computer.
Comment back if you need a pro, otherwise you should be able to simply reformat the drive and continue using it.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
I conected wd to mac book pro and the computer asked me if i want to use the wd for back up and i said yes.now all my files that i had there before does not recognize on my pc or apple.i can only use as a...
You will need to recover the data using something like asoftech data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to plug that drive into another Windows system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
Good luck.
Aug 19, 2011 | Western Digital My Book Essential Edition...
I recently bought a 1.5 terabyte My Book Essential external hard drive. I am trying to copy files from one external hard drive to another with the help of my MAC laptop iBook G4). The laptop detects...
I would suggest copying the data to your My Book as an interim step before copying to the second drive. Copying directly from one removable media device to another will necessarily move the data to your computer temporarily anyway, so there is no disadvantage to simply using your My Book as a middleman in the process.
Dec 20, 2010 | Western Digital My Book Essential Edition...
I connect the hard drive to my computer my computer detects but doesn't do anything i tried different usb cables and made no difference
Go to disk management and check whether the externall HDD has been detected and drive letter has been automatically assigned.
Thank you for using Fixya.
Jun 21, 2010 | Western Digital My Book Essential 1TB...
Hard Drive not recognised
If you are trying this on XP or other Windows OS, find out if it gets detected or not. you will find a icon below in your desktop
If this icon is on your taskbar and you are still not able to find the drive then you might need to manually configure the drive and partition in your computer management.
To go to computer management and assign drive letter to your drive detected follow below
go to start->control panel-> administrative tools->computer management-> locate disk management-> on the right side pane you might find detected hard drive but no drive letter-> right click the drive and select change drive letter and path->click on add->from assign the following drive letter select a drive-> click ok-> and your new drive will be assigned a drive letter and you can access your drive.
Below are the screenshots to do it. Hope this helps
May 23, 2010 | Western Digital My Book Essential Edition...
External Drive WD is not visible in Mycomputer.
right click on my computer
select manage
then disk management
identify the correct drive
right click and format,
once formatted remove
then plug back in,
you should beable to then see it under my computer
Jul 06, 2009 | Western Digital My Book Essential 320GB...
Itunes on external hard drive
If you want to move itunes to an extrnal driver, ..plug in the external, click my computer..open the local driver, look for " my music icon" and scroll it to the extenal driver icon...or right click the " music and where it says save..save to external driver.
Jul 03, 2009 | Western Digital My Book Essential Edition...
New external harddisk cant be detected on my computer
Since you have not given any specifications about model of your HDD hence I'd consider your HDD connects through USB. Your USB driver is old you shall consider upgradation.
Jun 15, 2009 | Western Digital My Book Essential Edition...
MAC Computer won't recognize Maxtor External Hard Drive
that disk is not detected by windows due to power failure to your hard drive. check power of your drive.
May 20, 2009 | Western Digital My Book Essential Edition...
Hard drive detection
You should not need a driver for it. Assuming you are using XP or Vista, the disk should be supported directly by the OS.
Have a look at external HDD troubleshooting.
Jules
Apr 22, 2009 | Toshiba 120GB USB 2.0 Portable External...
Hi, I recently bought your 750GB My Book external drive, which I have connected to a Macintosh G4 desktop computer.  The computer does not recognize the external drive now, although I was previously able...
Be sure to plug the USB connector and the back of the CPU. Then go to Application folder if your running on OS X. Locate the disk utility, then double click it and see if your external drive have been detected. If it is detected try to repair it. and then thats it
Dec 07, 2008 | Western Digital My Book Premium ES...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
388 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
