Question about Linksys Wireless-G WRT54G Router
Adding a printer
I would like to add a printer to this router. How do I this and how do I config. the computer. I am running Windows XP Home Edition. Thank you
  • lkennedy3 Nov 18, 2007
    I'm also trying to set up a fax/printer and the machine will not connect to the router??????trying to set up Brother MFC 665CW
  • birch530 Nov 19, 2007
    I do have a printer that has Ethernet connection. It is the HP6280. How do I set up this printer?
    Thanks
    Scholar:
  • 34 Answers
Unfortunately this model of router has no support for directly connecting anything other than a printer that already supports Ethernet.
Since that's not the case with most consumer printers you will need to buy a "Print Server" These are made by all the main manufacturers, and come with a collection of interfaces, USB / Parallel of the printer, and Ethernet or WiFi of the network side.
They all pretty much do the same thing so go for one that meets your needs.
If my advices was at least helpful, please vote for me!
Posted on Nov 19, 2007
I cannot get the printer Canon MX870 connected to the computer network. I am running windows XP I have it connected to the home router but when I put in printer name while adding the printer on the...
You cannot just add network printer on Windows XP without the printer software. You can only install it on Windows 7 with no software.
You need to get the canon MX870 software and run it on the computer you want to print files from. 'Before you do it, make you have already setup the printer to connect to your router and also make sure that it is connected to your router before you run the software.
http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx870#DriversAndSoftware
Select Windows XP (NOT WINDOWS XP 64) then download and install the first file "mp68-win-mx870-1_04-ea24.exe" Run it and it will show you options. Choose setup wireless there you go! Make sure you are connected to the-same router the printer is connected to.
Please rate 4 stars if this solved your problem. Thanks
Apr 26, 2011 | Office Equipment & Supplies
Do not have a problem. I wish to share a printer on the main computer runnng Windos XP, from my laptop which is running on windows 7 home edition. I have the router installed and working on line. Works...
Load the software on the second computer ... tell the wizard that the printer is connected to the first computer. Everything should work from there.
Thanks for visiting today.
Dec 30, 2010 | D-Link Wireless N 150 Home Router 4Port...
I have a TSP700 parallel port label printer and now have a new computer with no parallel port, so I purchased an adapter;- parallel to USB, but having tried every thing, I am running, windows XP pro, I...
you might need to fiddle around with the usb virtual printer port configuration , when you add printer. when adding a printer, uncheck the install automatically tick box, then on the NEXT page click on the drop down list of "use the following port" and try virtual port. it might work.
Mar 21, 2010 | Star Manufacturing Star TSP700 Receipt...
How do I remove the mighty pc add that keeps
go to add or remove there select that uninstall it
Mar 09, 2010 | Microsoft Windows XP Home Edition
Windows XP - need to restart Wireless Zero Configuration
type this in command window sc config wzcsvc start= auto
Oct 07, 2009 | Microsoft Windows Xp Home Edition Sp2...
Systemax tiger P.C.
you have to turn the graphic accelortor down, or install a fix. you should be able to click here and select your system config. and install the drivers needed. some systems before vista just arent compatible right out of the box. thanks and pls post a response if you need any additional help.
Jun 27, 2009 | Microsoft Systemax SG 1350 Gaming Desktop...
Xp home & wireless printer won't install
Add the printer in a TCP/IP port and assign it that IP address. /Add Printer/local connection then set it to TCP/IP port and the printers ip address.
Jan 15, 2009 | Microsoft Windows XP Home Edition
Can't connect network printer to Windows XP laptop
Does this computer see the other two computers and do they see this computer?
Sep 18, 2008 | Microsoft Windows XP Professional With...
Usb upgrade
Let's see if I understand - you have added an additional card into the computer which adds USB v2 ports. Then I guess you are plugging a USB Wireless card into those ports.
Can you see the speed of the wireless connection? If you 't have an icon in the lower right hand corner for the card, hover over it with the mouse, or right click. Otherwise, go to Control Panel, Network Connection and look for the wireless card there.
Right clicking either one should show you the speed between your computer and the router.
Most wired connections will be 100 Mbps. Depending on the card and the router, wireless will be 10, 56, or 108 Mbps.
Wireless speed depends on many things, such as:
1) distance from the computer to the router
2) number of solid objects, such as walls, floors, or metal
3) possible interference from other wireless routers in the area
Do you think any of these are at work here? If you can reposition either the router or the computer, it may help.
Wireless is cool, but the best possible speeds will always come from a wired connection. I have my desktop computer wired, but my laptop wireless. When I go wireless, my speeds drop.
Tell me a bit about the equipment you're using, perhaps we can squeeze a bit more out of it.
Hope that helps!
airoff
Jul 22, 2008 | Microsoft Windows XP Home Edition
I have acer aspire laptop computer model 3692WLM1 windows media center edition I wish to purchase a HP DESKJET D4200 series printer will this be compatable for my laptop
Hey doodee,
According to information provided by the manufacturer, this model HP printer requires Windows 2000, Windows XP Home or Windows XP Professional in order to function. Apart from the obvious cosmetic changes and some extra added functionality, Windows XP Media Center Edition may be treated as basic Windows XP in many instances. As such, this printer should be compatible with your computer. Please keep in mind however, that you may need to perform driver and software updates in order to guarantee functionality.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 11, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
187 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
