Question about Craftsman 20 Hp 42" Deck Lawn Tractor
When letting out brake on lawn tractor it begins to backfire
  • 4 Answers
If you have overhead valves, it is likely they are out of adjustment. These overhead valves are notorious for this, even having the retaing nut or the entire stud coming loose, or off. often the pushrod running loose against the guide will wear it entirely in two. Don't get too worried, these parts are relatively cheap, though having them installed and the valves properly set may cost a few bucks. be sure someone experienced with this problem does the repair or the valve will continue to come loose. This may not be your solution, but with backfiring, valves or ignition timing. Generally those two are the culprit. Yours backfiring under load makes me lean towards the valves.
Posted on Oct 16, 2009
Brake system
Michael, Check the attached links, 1st link is snapper where you can get info from support,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tractor Riding Lawn Mower Products Snapper Mowers Tractors
Snapper Lawn Mower Transmission Brake Clutch Parts
Snapper Brakes
Snapper Lawn Mower Parts Lawnmower Parts Discount Online Parts
Apr 09, 2016 | Snapper Garden
I have an 18 hp LT2000 lawn tractor, motor runs fine with clutch/brake depressed. As soon as I let off clutch/brake motor backfires and dies, It does this even in nuetral. I have the mower deck off and...
Hello, W/D here.
Everything is tied to the seat switch, to make sure that the operator is on the seat before the machine moves or mows. Most often, they loosen up, and the contacts don't make/ Check the switch under the seat, looking for it being out of adjustment. Tighten it back up if it is loose. Replace if necessary.
Best regards, --W/D--
Feb 08, 2011 | Craftsman Garden
My toro wheel horse tractors & riding mower 31-12K801 312-8 keeps backfiring when I am mowing the lawn and stops and will not turn back on until you let it set for awhile. I had replaced the spark ...
I had a mower with exactly this behavior. Mine had a 14 HP Kohler Engine. After considerable frustration, we replaced the electronic ignition module, and it has worked perfectly since then.
Aug 17, 2010 | Sport & Outdoor - Others
BACKFIRES WHEN YOU KILL IT.
Let it idle for 5 minutes before shutting the engine off to stabilize the internal temperature, that should stop the backfiring which is fuel lighting off when hitting the hot combustion chamber surfaces.
May 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Last weekend I sharpened the blades, changed the oil filter, the oil, and the spark plug, put in fresh gas and started the mower up and mowed the lawn no problem. This weekend, it started right up but when...
There is an operator presence switch under the seat...if the mower shuts off when you release the brake, this switch is faulty and must be replaced
May 02, 2009 | Garden
Engin backfires and cuts out when hot
Hello:
>>From your Description it Sounds like a Bad Ign Module or Ign Coil.
>>Replcace the Ign Module/Coil.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
144 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
