Question about iRobot 5800 Scooba Vacuum
Scooba now stops sooner and isn't finished cleaning :-(
It used to do three rooms and not quit- now won't finish one without me having to press power again. I really love this thing and want it to work like it used to!
I had this problem and contacted irobot. An important fact was left out of the early edition user manual to not leave the battery charging for an extended amount of time. Because of this ommision, they sent me a new battery and a software upgrade for the scooba. I just followed the directions and attached the little device they sent to do the upgrade the scooba and it fixed the battery problem.
Hope this helps.
Posted on Feb 03, 2010
Number of rooms is irrelevant - runtime matters. it runs for about an hour or so with a good battery. my second battery has now only about 15min runtime after about 20 cleaning cycles - just like the first one. There is something wrong with the robots charging algorithm. some research on iRobots website showd that there might be a factory software upgrade available to fix that. maybe ask iRobot about it.
Posted on Jan 17, 2010
  • iRobot Master
  • 5,568 Answers
One or more battery cells have failed in its pack; you will probably need to buy a new one. One review of a new machine stated that it would only do a single room on a full charge.
Posted on Jul 17, 2009
  • 3 Answers
After not using my scooba for quite awhile, although it was continuously plugged into the electric, now when I try to do my floors after it charges to the steady green light is on but only works for less than a couple of minutes....why?
Posted on Nov 10, 2009
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • Dec 22, 2012 | iRobot 5800 Scooba Vacuum
    It leaves water after finished. That's the first time I use it but it leave water on the floor and it stops.
    According to iRobot make sure that the Scooba is clean, including the parts (vacuum hose & filter, bottom roller)
    Make sure the battery if fully charged, and that you let it complete the cycles!
    May 15, 2010 | iRobot 5800 Scooba Vacuum
    Irobot scooba 5800 spins quickly then sets off backwards
    Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
    May 10, 2009 | iRobot 5800 Scooba Vacuum
    Scooba says check tank and won't move.
    Rinse the four ports on the underside of the tank with warm water, particularly the round opening that covers your Scooba's vacuum port and the curved one that matches the filter. Odds are, there's a clog in there and your Scooba knows it. Rinse the two oval ports as well, as thoroughly as you can.
    Also, try priming the pump with water. The iRobot website shows how to do this under the Scooba troubleshooting section.
    Then run the unit with water and vinegar (in place of the Clorox Cleaning Solution) if possible.
    May 10, 2009 | iRobot 5900 Scooba Robotic Wet/Dry Vacuum
    Can you use irobot Scooba on laminate floors?
    they are suppose to be hardwood floor safe but maybe you should call the manurfacturer and make sure
    Mar 21, 2009 | iRobot 5800 Scooba Vacuum
    Scooba in diagnostic mode
    This is a common issue :)
    his morning, I turned on my Scooba and it started beeping a scale of tones and blinking all its lights in sequence. After an hour or so of resetting, cleaning, disassembling, researching, and scratching my head, I stumbled across the solution on Roomba Review. But, for me at least, it was even easier than all of that. I don't have any of my own pictures for this procedure, but it's pretty straight forward.
    • Remove the battery and power.
    • Remove the two screws holding the bumper shell in place and remove it.
    • Carefully peel up the sticker with the control buttons on it. This sticker is actually the control panel. There is a data cable attached to it just below the "Clean" button. Be careful not to break it!
    • Clean the surface under the sticker with some isopropyl alcohol. (I didn't actually have to do this, but I'm sure it doesn't hurt.)
    • Gently replace the "sticker" (i.e. control panel) and make sure it's completely flat.
    • Check to see if it works again. If not, repeat.
    • Replace the bumper shell and screws....
    thnx.
    Jan 23, 2009 | iRobot 5800 Scooba Vacuum
    Scooba circles and only goes backwards.
    try cleaning the cliff sensors under bumper
    Dec 13, 2008 | iRobot 5800 Scooba Vacuum
    Stuck on check tank indicator
    If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
    1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
    2. Remove and reseat the brush head
    3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
    4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
    5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
    6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
    With the tank removed, press the Power button and then the Clean button.
    If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
    If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
    Below is a link to a diagram of these steps for visual reference:
    Title: Scooba is not putting down cleaning solution
    http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
    Nov 01, 2007 | iRobot 5800 Scooba Vacuum
    Scooba 5800 Power button Red Blinking
    You probably have the manual, but here's the link to the Scooba 5800 manual anyway - just in case this would be useful to you: --> http://www.irobot.com/images/homesupport/5800_Scooba_Manual.pdf You could use a voltmeter to check the battery, but only a few months use shouldn't be enough to wear it out. If you don't have a load-tester to verify the battery's load-capacity, then you can check the voltage drop. (Assuming you can get it to contact the Scooba's circuits.) To do this, just check the battery voltage, apply a load by inserting it in the machine and turning it on, then check the battery voltage again. An excessive drop in voltage may indicate the battery needs replacing. However, the red blinking light is Scooba's indicator that it doesn't detect the battery at all. The first thing to do in this case is to clean the electrical contacts on the battery and in the Scooba. Use a damp cloth and a bit of toothpaste to rub the contacts clean on the battery and in the machine. (Toothpaste has mild abrasives in it and will clean the electric contacts without damaging them.) Make sure that both the battery and the Scooba are clean and dry before re-inserting the battery. Also, if the electric contacts in the machine are flexible matal tabs then verify that the tabs are standing up high enough to make good contact with the battery contacts. Hopefully the battery just needs it's contacts cleaned for your unit to work, but test the battery if you are sure that they are clean and seated properly to the contacts in the machine. If the battery appears to be failing, then contact www.irobot.com to cheack and see if they are still covered under your machine's warranty. Hope this helps! :)
    Aug 06, 2007 | iRobot 5800 Scooba Vacuum
    iRobot 5800 Scooba Vacuum Logo
    795 people viewed this question
    Top iRobot Vacuums Experts
    Shehu Pro
    Shehu Pro
    Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
