Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sensors only orange not green
Both sensor lights only go orange even if I put them right next to each other...
  • 2 more comments
  • jejitaly Jul 17, 2009
    The door light blinks 4 times and will not close unless I hold down the button. If I release it anytime before it is fully closed it will open all the way. it was blinking twice and I switched the wires around to try every combination. Also, I have held the two sensors together to make sure alignment is not the problem during all troubleshooting
    The door light blinks 4 times and will not close unless I hold down the button. If I release it anytime before it is fully closed it will open all the way. it was blinking twice and I switched the wires around to try every combination. Also, I have held the two sensors together to make sure alignment is not the problem during all troubleshooting. Also, I took the sensors and only left 1 foot of wire off them and hooked them directly into the head unit facing each other.
  • klipsch2345 May 11, 2010
    Are the wires reversed or shorting out on each other?
  • Don Maggard May 11, 2010
    Are you having a problem with the door not closing?
    President:
  • 3,197 Answers
I would say you have a bad logic board.
Posted on Jul 17, 2009
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
Garage door will not stay closed - one sensor is showing a green light and the other one is showing an orange light - i have tried to adjust position with no luck
When the two sensors are completely aligned, both sensor will show green lights. Usually the green light is your sending side and the orange/red side is the receiving side. You can measure the distance from the ground on the sending side and then adjust the receiver end to the same to get you in the general ball park and then fine tune it from there.
Jul 10, 2011 | Vacuums
Where is dish network DVR VIP622 IR sensor location
Hello, Daniel Busa with Dish Network's customer service department. The ir sensor would be right below the blue green and orange light on the reciever.
Oct 26, 2010 | DISH Network ViP622 DVR DTV Receiver /...
I have liftmaster professional garage door opener. it opens ok but does not close with remote and light keeps flashing on garage door opener. I checked both sensors and seems like the sending sensor light...
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
THE WIRING ON THE FAN CLUTCH GOT CUT AND THE WIRES FROM THE TRUCK ARE YL/RD,BLK/RD,GREEN/GRAY,RD/GREY,GREEN THE WIRES FROM THE CLUTCH ARE RD,GREEN,WHITE,ORANGE,BLACK. TRYING TO BE SURE BEFORE I CONNECT...
1) ECM Fan Clutch 1) K160 18BR/OR Park Lockout Solenoid Control Green
1) BR / OR = Brown/Orange unit with Green
2) K900 18DB/DG Sensor Ground 2) Black
2) DB / DG = Dark Blue/Grak Green unit with Black
3) K161 18BR/LB Fan Speed Sensor White
3) BR / LB = Brown/Light Blue unit with White
4) Not Used
4) Not Used
5) F856 18YL/PK 5 Volt Supply Orange
5) YL/PK = Yellow/Pink unit with Orange
6) F504 20GY/PK Fused Ig. Sw. Output Red
6) GY/PK = Gray/Pink unit with Red
With this, you have 5 due color cables unit to the 5 full color cables. Run.
Good luck, and rated this help (and us chat).
Aug 27, 2009 | 2004 Dodge Ram 3500 Truck
Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
Apr 14, 2009 | Washing Machines
Zebra 2844 printer green light turns Immediately orange
Clean the "cover open sensor"
location: open printer, it's at the right hand side of printer, beside the green edge guide adjust thumbwheel, in line with edge guides.
Mar 27, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Even though the engine is not cold, the blue light keeps blinking
you need to change the oil heat sensor. it's fairly simple. the sensor is located just below your air cleaner at about the 10 o'clock position. it sits right in the middle of the coolant hose so make sure that your car is not hot or warmed up. just pop the plastic clip off and take the sensor out and put the new one in. make sure that you dont leave the o-ring in there you should replace it as well. the o-ring is a factory part & costs about 10.00 and the sensor you can buy at kragen or other auto stores for about 12.00. it isn't expensive at all. I had the same problem. i changed the sensor and it stopped.
one more thing. you should get the sensor that is green. it's better than the black one that is probably in your car right now. Good luck.....
deborah
Mar 10, 2009 | Volkswagen New Beetle Cars & Trucks
Garage sensor problem
The colour on the sensors doesn't change.
One is orange constantly and the other is green when detecting a signal from the orange sensor.
If the green is flickering, they are not adjusted correctly.Move the green sensor until you get a good solid green. Holding the wall pad button down, just bypasses the sensors.
Try adjusting only the sensors so that they are solid.
In addition, check the little yellow light on the back of the machine and count the flashes.
The number of flashes will tell you what the error is in your manual.
Jun 18, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Won't print
it could be a lid open sensor issue, if you put pressure on the lid does the light turn green? it is common for ir sensor to fade over time and if the reflectiveness of the case above the sensor fades you get this error too. the sensor is to the right of the roller and if you clean or place a sticker on the LID facing the sensor it can fix the problem
Dec 03, 2007 | Zebra LP 2844 Thermal Printer
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
322 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
