Question about Culligan Under Sink Water Filter
Two led water purity monitor problem
I have a two led water purity monitor for water tower. I open the faucet and push the test button, I just watch red led blink one time and it does not work at all. I do not know what is the correct led display way? I guess when you push the test button, the led will be on until you release test button. Now I do not know my monitor is bad or I need service for filter.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
The LED monitor should light up as Green when the membrane is producing the proper water quality (80%+ TDS rejection). If the LED light stays Red this indicates the RO membrane is bad, all the filters (including membrane) should be changed and system sanitized. The batteries in the TDS monitor should be changed yearly also. Don't have a lot of faith in that indicator light. The best way to test for TDS rejection is with a digital TDS meter which indicates the amount of rejection. Compare the incoming water to the product water of the RO.
RJ
Posted on Jun 25, 2011
I want rotate my Grohe ladylux kitchen faucet. The handle is on the left and I want to rotate to the right side. How do I do it? Thank you John
You will presumably be pushing the faucet handle away from you instead of pulling it forward? If you don't like it, you can always put it back.
Turn off the water.
Release the water in the faucet. If you have a faucet in a room on a floor below, open that to drain the water.
From underneath the unit, back off the nut that is gripping the worktop. Slacken off the hot and cold supply pipes. I am hoping you have braided flexible hoses, or you can't do this job very easily.
Spin the faucet 180'.
Retighten the hold and cold supply pipes.
Retighten the holding nut.
Turn on the water and open the faucet.
Check for leaks.
There is an installation video here.
https://www.youtube.com/watch?v=sQgi0CMAxYM
and some further information and diagrams here.
Removing Grohe LadyLux Caf 33 755 Faucet Handle
Jan 02, 2016 | Grohe Plumbing
The red pressure relief button on my GE Smartwater whole house water filter system is leaking what do i do to stop this
I had the same problem. The valve is not seating properly. I first took a plastic bag and placed it over the unit so it didn't spray all over, then, pushed the button several times to try to flush it. I then shut the water supply off (or move lever to bypass) and removed the cannister that holds the filter. I activated the red button several times until it looked like it seated well. Keep as much water in the cannister(sump) as you can and still have the filter seated properly. Screw it back on, and open the water supply slowly to fill the rest of the way. Don't push the red button again, but instead open a faucet in your house for around 5 minutes to let air circulate out. If the red button still leaks, you may have to try a few times. If it leaks just a little it may stop after a day or so. Once you get the red button to stop leaking, don't push it again! Just always use the open faucet method to work the air out. There will still be some air bubbles for awhile, but will work out within a day
Sep 13, 2012 | General Electric GE SmartWater Household...
My dell 4600c monitor will only show a picture when i start or restart it with the monitor power button. it is only on for about 1.5 seconds each time.
If the tower power LED is a Steady Green and the Diagnostic LEDs on the Back are all Green then the monitor itself appears to be the failure point. See if issue occurs with a different monitor. If the tower LEDs are not all green, then reply with the indications
Sep 20, 2010 | Dell Dimension 4600 PC Desktop
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
Dec 15, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
My screen is showing Self test feature check and will not stop! Help!
The first thing to check is--is your computer actually running?
It sounds like your computer is either off or it is not sending a video signal to the monitor.
If there was a signal going to the monitor, you would be seeing something other than self test.
There is also probably a menu button on the monitor. Find it and push it to reset the monitor.
Now check your computer--preferably with another monitor to see for sure what is going on.
Oct 22, 2009 | Dell Computers & Internet
Dell monitor dialog box says monitor is in the power save mode
Actually, it most likely is not the monitor which is in "power save mode", it is the computer itself.
When you cannot get a computer out of "power save mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty.
Usually, this happens on a computer which is a few years old, since its batteries will have run out after such a long time. (The motherboard battery is used to store various settings when the computer power is off, such as date and time. When your computer detects this battery is empty, it goes into a low-power mode).
The solution is to replace the button-cell battery on the motherboard of your computer:
  • open the case of your computer;
  • visually locate the motherboard (the main electronic circuit board) of your computer;
  • visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
  • remove this motherboard battery from your computer;
  • restart your computer: it should now power up normally (you may get some warning messages during the start-up sequence, but ignore them);
  • set the date and time of your computer using the "Date and Time" control panel;
  • you can now use your computer normally, but you will lose date and time settings when you disconnect the computer power cord, since there is no motherboard battery present to store them;
  • take the motherboard battery to an electronics store and get a replacement;
  • install the new battery in your computer;
  • restart your computer, and set the date and time again; the settings will now be saved using motherboard battery power.
Dec 06, 2008 | Dell Dimension 2400 PC Desktop
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Culligan Under Sink Water Filter Logo
244 people viewed this question
Top Culligan Tools & Hardware - Others Experts
Jim London
Jim London
Dan Connors
Dan Connors
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
