Side-by-side
Mounted behind the refrigerator temperature control knob... Maytag Refrigerator Temperature Control Thermostat WP61005651
It could just be that your freezer thermostat is not set low enough. Try adjusting the thermostat to a colder setting.
Or your icemaker might not be making ice because of a defective defrost thermostat. Test your defrost thermostat to determine if it has malfunctioned. If it has, you will need to replace it. side-by-side refrigerator, the defrost thermostat is found at the back of the freezer side. The thermostat is wired in series with the defrost heater, and when the thermostat opens, the heater shuts off. You will have to remove any objects that are in your way such as the contents of the freezer, freezer shelves, icemaker parts, and the inside rear, back, or bottom panel.There are two wires leading from the thermostat. They are attached to terminals with slip-on connectors. Gently pull on the connectors to release the wires from the terminals. You may need to use needle nosed pliers to help you. Do not pull on the wires themselves
Set your multitester to the R X 1 ohms setting. Place each of the multitester's leads on a thermostat wire. When your thermostat is cold, it should produce a reading of zero on your multitester. If it is warm (anywhere from forty to ninety degrees Fahrenheit), then this test should produce a reading of infinity. If the results you receive from your test differ from the ones presented here, then you will need to replace your defrost thermostat.
