American Exchange Comfort 14,000 Btu Acw800ch Portable Air Conditioner Logo
b
bruno lapolla Posted on Jun 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is the air not cold enough when the ac is on
When on ac mode the air is not cold enough
richie46
Level 3:
Top Expert:
  • American Exc... Master 12,962 Answers
  • Posted on Jun 20, 2016
richie46
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945108
Points
58151
You have probably leaked refrigerant and need some more to replenish what you have lost. You might consider refilling with the refrigerant that has some stop leak in it to seal up any small leaks so that you do not lose the freon again.
With two wrenches tighten up all fittings in the ac line. Over a period of time, the engine vibrations and aging will loosen them and cause systems to leak.
I have a 1999 olds aurora an when ac is on it only blows hot air the refrigerant is full an ac clutch comes on
If you say clutch comes on, did you try feeling the suction pipes. If its not cold enough, you may have a poor ac compression. If its cold indeed, then the cold air may have been diverted elsewhere and this is caused by faulty hvac door actuators or faulty air mix controller. ?
tip
Why your unit is freezing up.
To understand why your AC or heat pump is freezing up, it helps to know how your system works.
There are 7 major parts to an AC system, 9 with a heat pump.
1 - Condenser/heat pump (The outdoor unit)
2 - Air Handler (the indoor unit unless the system is a package unit, then all is outside in one system. The air handler is usually found under the home, in an attic, or in a closet.)
In the condenser are the following major parts.
3 - Compressor
4 - Condenser coil
5 - Condenser fan
6 - (HPs only) reversing valve
In the air handler are the following major parts.
7 - Blower motor
8 - Evaporator coil
9 - (HPs only) electric heat strips
Some systems known as "dual fuel systems" use another heat source in place of the heat strips, usually a gas furnace. I will address gas furnaces in another post.
When an air conditioner is operating properly several things are taking place.
1 - The compressor is compressing or "pumping" refrigerant through the system.
2 - through changes in pressure, the refrigerant makes the evaporator coil get very cold, and the condenser coil gets very hot.
3 - The blower motor/fan circulates air across the evaporator coils, as the room temperature air (Also known as "indoor ambient") goes through the cold coil, it exits, cooled approximately 15 to 20 degrees cooler than when it entered. (In a ducted system, the blower is also the fan that circulates the air throughout the home.)
4 - The condenser fan circulates air across the condenser coils. As the outdoor air goes through the condenser coil, it removes heat from the coils that are very hot. This in turn removes heat from the refrigerant so it can run its cycle again, and through pressure changes, cool the evap coil.
5 - With a heat pump, the reversing valve reverses the flow of refrigerant in the condenser and evaporator coils.
In AC mode, the evaporator coils get cold, and the condenser coils get hot. But in heat mode, the evaporator gets very hot, and the condenser very cold.
Now, whichever coil is getting cold will freeze up if there is inadequate air flow across the coil, as the refrigerant in it is far below freezing, and there is not enough airflow to keep the humidity in the air from freezing on the coil.
Things that can cause poor airflow are,
1 - Dirty/clogged coils
2 - dirty/clogged filter (will only effect evaporator coil)
3 - Closed/blocked vents (will only effect evaporator coil)
4 - Malfunctioning or dirty fan
Low refrigerant will also cause a coil to freeze up, reduce efficiency and cause the system to run for long periods of time. Not to mention, shortening the life of the unit.
With a heat pump, in heat mode only, the condenser (outdoor) coil will routinely begin to freeze up in cold temperatures. This is due to the fact that the refrigerant is below freezing, and the cold outdoor ambient temp is not warm enough to keep the condensation in the air from freezing on the coil.
Note, a properly working AC should never freeze up.
A heat pump is equipped with defrost controls to prevent ice buildup.
Some are controlled by timers, some by temp.
When a HP is going into defrost mode, the condenser fan shuts down, the reversing valve reverses the flow of refrigerant and the once cold condenser coil now gets very hot, defrosting the coil. (Many people have said this process sounds like the unit is coming apart, or about to explode and are frightened by the "smoke" which is really just steam from melting ice that comes off the unit.)
During defrost mode, the secondary or "auxiliary" heat comes on to ensure that you are still getting warm air from the vents. (Again, this can be electric heat strips or a dual fuel system)
If you are experiencing cold air from the vents during defrost, that means your auxiliary heat is malfunctioning.
The auxiliary heat is used for three purposes.
1 - during defrost mode to maintain warm airflow (automatic)
2 - when the HP cannot maintain the set temp due to extreme outdoor temps. It comes on when the indoor temp drops several degrees below the set temp on the thermostat (automatic)
3 - For emergency heat source when the HP is not working. (Manual)
To recap....
Iced up coils?
Poor airflow
low refrigerant
Malfunctioning fan
failing defrost system
There are two things that can be done in a pinch to help de-ice frozen coils. This may get you by until the repairman can get there, or you can fix the system if you are a do-it-yourselfer.
HPs frozen outdoor coil in heat mode, not going into defrost?
Cover most of the vents, and turn the system onto cooling mode until the outdoor coil is thawed. then uncover vents and return to heat, or emergency heat. (this usually takes 15 min or less)
Frozen coils in AC mode with a heat pump?
Turn the system to heat with the thermostat on just high enough to get the system to come on. (again, usually takes 15 min or less to thaw.)
AC only, with frozen evap coils? (this can sometimes be seen frozen all the way outside to the compressor on the copper lines.)
Turn the system off, and the fan switch from "auto" to on".
This will usually defrost the coils within 1 to 2 hours.
(If your system has the furnace in line before the evap coil, turn the system to heat, and the furnace will defrost the coil within minutes.)
My kenmore 12000 btu portable air conditioner keeps switching to DH mode out of AC mode
That means that it is dehumidifying. Is the air coming out still cold? I assume you have tried using the mode button to switch it back? Is the air extremely humid? Perhaps it is humid enough that the machine needs to dry the air before safely operating as an AC. The manual is available here:
http://www.sears.com/kenmore-portable-room-air-conditioner/p-04272012000P
Why does My thermostat Not switch between ac,heat,defrost . there's cold air coming out of vents but not cold enough to be ac. Initially when this started the ac was blowing hot air
If the air flow cannot be controlled from vent/defrost/floor you may have a blend door issue. This is an electric motor that operates a door in the heating system to control airflow. There are usually 3 motors controlling airflow direction,heat and recirculation. The Ac not blowing cold may also be another problem. If the AC is operational, the compressor will be engaged and the Ac low pressure line under the hood will bw cold. If this is all ok then a blend door issue should be suspected
My new ac unit isnt blowing out cold enough
What's the temp been out side? If its over 95 degrees only expect you air to blow at about 75. It's an air conditioner not a cold air maker.
Ac turns on and the fan blows air but not cold air. When switching from fan to ac mode i hear a buzz sound like it had switch to ac but still its not blowing out cold air. Any suggestions?
mcdevito75, Needs service either a chrge of freon or the need for a new thermostat and That is what it sounds like to me, (the compressor could be bad also, the buzzing sound) hope not expensive repair.
2helpful
Portable ac blows warm air even after i cleaned filter
Make sure that the coils are all clean, Vacume cleaner with the brush attachment on the end works well.
Sounds like your fan is only working and not the Compresser that makes the unit an "air conditioner" and not a gloryfied fan.
Check and make sure that the butten is on Cold and that the small water drawer is in correctly so the shut off switch is making good contacts. Important Make sure that it is getting enough electricity at the wall plug, Because when the ac compresser 1st turns on it uses 3-5 times the power for the intial startup, not enough juice means no AC.
The fan only uses a little to blow but AC needs alot to start.
Unit should sound diffrent when AC compreser turns on compared to fan only on mode.
Ac doesn't throw cold air
hello friend, All the compressor work in above 190 v. please additional fitting in voltage stabilizer okkkkk
1helpful
Air conditioning
You need the AC mode/function switch to be replaced, it controls the different modes the AC/Heater are set to and where the air goes within the air ducts..
Cool/AC light is blinking
Try cleaning the filters & coils good with a shop vac, or a scrub brush.
Top American Exchange Heating & Cooling Experts
Paul Carew
john h
Are you an American Exchange Heating and Cooling Expert? Answer questions, earn points and help others
