Question about Yamata FY101-1A
HI I WOULD LIKE TO KNOW HOW TO ORDER A SPOOL PIN FOR THE LARGER THERAD AN A BOBIN CASE FOR DISNEY SE-2700
Kens sewing and vac.com
Posted on Aug 23, 2009
The top thread will not pickup bobbin therad it is a pfaff 5.0 machine
The bobin may not be in correctly. When looking at the bobin, with the thread threaded through the bobbin case, make sure that it spins counter clockwise. Also the problem could be caused by the machine not threaded correctly. But it is more likely the bobbin case and bobbin
May 04, 2017 | PfaFF Sewing Machines
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    I have a Brother Disney SE-2700 and the bottom threads knott up causing me to not be able to sew.Please help.
    It sounds like it has not been correctly threaded or the tension is too tight. Check the tension discs for bits of thread that may have broken off and be causing a blockage.
    Re-thread the top threads making sure the pressure foot is up before passing the thread through the tension discs!
    Then check the bobbin is running correctly by pulling on the tail of the thread. The bobbin should rotate clockwise. Put the bobbin case in and make sure it is seated correctly.
    If all this fails try replacing the needle. A blunt needle can cause all sorts of weird problems
    Mar 24, 2011 | Brother Disney PE-400D Computerized Sewing...
    How to therad the bobin and the machine
    try getting a manual from the Singer web site
    Dec 08, 2010 | Singer 2263 Mechanical Sewing Machine
    Designer SE hit pin head while sewing.
    did you take out the whole bobin case and see if it has a piece of the broke needle in there?
    Jul 22, 2010 | Husqvarna Viking 1
    Bobin
    The thread should un-spool clockwise when looking down at it.
    good luck!
    Jan 10, 2009 | Kenmore 19233 Computerized Sewing Machine
    Lost Spool pin and cap for QuikStitch SP-402
    Welcome to FixYa. If you have a spool stand, that might work as long as you can thread the machine properly (give it a try!). When the thread is placed on the machine's spool pin, the spool cap keeps the thread in place and helps the thread unwind evenly - so if you are using a spool pin, you really do need a spool cap.
    If the spool stand works, you are good to go. If you need to order replacement parts, I've provided a link the manufacturer's website. From there, you can contact customer support and find out if parts are available. If you can't order replacement parts, ask customer service if the machine is compatible with another brand. Another option would be to buy a spool pin and cap at a sewing machine dealer. Take the machine with you and and make sure the parts fit before you buy them.
    Here's the link to the site I mentioned:
    http://www.topinnovations.com/products/sew/SP-402/SP-402.html
    Thanks for stopping by. If you have an extra minute, feel free to rate my solution. I'm eager to improve my solutions if they are not helpful. If you have further questions or would like to consult with another FixYa expert, just leave a comment and I'll do what I can to resolve your problem.
    Oct 25, 2008 | Sew Pro QuickStitch SP-402 Mechanical...
    Need manual for 11301 barbie sewing machine
    Anyone who needs a Manual for this Barbie machine I have it in pdf.
    Someone tell me if they want it posted.
    thanks,
    Bonnie
    May 03, 2008 | Barbie 11301 Mechanical Sewing Machine
    Sewing Machines Logo
    Top Yamata Sewing Machines Experts
    Lyle Siemens
    Lyle Siemens
    isaac johny
    isaac johny
    Michael Kovalik III
    Michael Kovalik III
    Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
