Question about Whirlpool Duet GHW9150P Front Load Washer
The letters F dl blink on the setting screen. What do they stand for?
  • 6,784 Answers
Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Posted on Jul 17, 2009
How to set the name plate on the brookstone electronic name plate
1) use a pin to press and hold "reset" to clear the display
2) press and hold "S" to get a blinking underline
for each letter, press the "C" triangle until you see the letter you want, then press the "E" square to enter that letter and advance to the next letter. when done, just wait for it to timeout.
I'm unsure how to display things more than 16 letters.
Aug 11, 2014 | Audio Players & Recorders
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Kenmore elite model # 110.45088400. We set a cycle, washer starts beeping and reads F then blinks to DL. We hit pause to clear then try to restart while it makes clicking sounds and it continues to read...
'DL' stands for Door Lock error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 24, 2011 | Kenmore Elite 45986 Front Load Washer
Have been using this HP LaserJet4Plus for a long time now with nary a problem. Just today, after it printed a few pages, it came up with the error ME (flashing) FEED DL. Now when I try to print, one page...
ME FEED DL is displayed when there is a request for a manually fed envelope.
The DL is the envelope size that it is looking for.
Put the aforementioned envelope in tray 1 and press ONLINE to print.
By the way, a DL envelope is 110 × 220mm. It is used on a 220V printer.
If you don't have one, cut a piece of paper that size and humor the printer by putting it in tray 1. Let it print and see if that gets rid of your problem. If not since you already tried Cold Reset, try NVRAM reset. Hold down JOB CANCEL while power cycling the printer.
Remember, this will set page count to zero and all other SERVICE MODE settings to defaults. But it will set tray 1 to LETTER.
Mar 25, 2011 | HP LaserJet 4 plus Printer
When I push the stand-by/on button - stand-by blinking
WHEN I PUSH THE STAND BY BUTTON THE UNIT GETS ON AND IMMEDEYETLY GETS OFF(YAMAHA RXV-995 IF IUSE 500VA STABULISER THAT PROBLEM NOT COMING PLEASE SOLVE IT
Sep 10, 2009 | Onkyo TX-SV373 Receiver
My external drive is no longer consistently recognizing 8.6 gb 2048 byte sector disks. it works sometimes after inserting and ejecting the disks multiple times. when the green light stops blinking i know...
Make sure you are buying the discs labeled DL
The DL stands for dual layer.
If you do not buy the DL you can not have the 8.6 gig write space.
I usually just buy R- DL(not the R+) since R- works on all the PC drives and all the old mac drives.
Jun 28, 2009 | Sony External SCSI-2 9.1 Gb Mo Drive...
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Washer won't start. falshing the letter F then the lower case letters dl.
DL means you have a draining problem.
Clean filter, drain and or pump
Jul 28, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal De
