Question about Eiki LC-SE10 Projector Multimedia Projector
I have an LC-SE10 and the power light will not even iluminate any color when plugged in. I checked the fuse in the back above the power input
  • 2,237 Answers
You need to replace the power supply.
Posted on Nov 18, 2009
Why won't my warning light turn off?
Probably a fan that doesn't rotate, or one of the many sub-voltages is absent on the mainboard due to short circuited capacitors ( SMD's)
Oct 25, 2012 | Eiki LC-SE10 Projector Multimedia...
My Sharp LCD panel color TV. does not have any power supply. When I turn on the power button, its power indicator led from red to green for split second and completely turn off without any life. What...
Good day!
This are the steps to find and fix that problem.
  1. Open the cover of your TV.
  2. Disconnect the input supply of system board or main board that comes from the power supply unit.
  3. Power ON the TV to check the voltage reading of disconnected connector to the input of system board by using voltmeter.
  4. Check the 5vdc and 12vdc by using voltmeter.If you got voltage reading of 5vdc and 12vdc,try to connect the input connector of the system board and check the voltage again.If no voltage when you connect it.There's a shorted parts on your system board.Replace the whole system board because its very difficult and expensive to repair it.
  5. When the input voltage of system board doesn't have 5vdc and 12vdc even disconnected on the board.The problem is on power supply.
Check the following:
  • Fuse-Check the fuse if busted.
  • Transistor and diode-Check the transistor and diode if shorted.
  • Resistor-Check the resistor if open/change value.
  • Capacitor-Check the capacitor if leak/bulge on top.
If you found the defective parts that mention above.Replace it with the same type and ratings.
NOTE:If the following parts are OK and the problem is still there.The power supply have major problem and its not for D.I.Y..
Thank you and good luck
Apr 25, 2011 | Sharp AQUOS LC-32D43U 32 in. LCD...
I am trying to find the fuse that lights up my shifter so I can see what gear I am in.
the power for the ilumination comes from the mlps switch on the side of transmission. If no ilumination suspect bad sensor.
Jan 06, 2011 | 2005 Ford F-150
My 06 GSXR 600 just died while driving, and the elect were also off, I waited over 3h and then tried to started back again but there were no Elec at all, not even the lights were on and there were a hint...
Hi first thing to check ins that you have 12 volts at the battery, it is unlikely that the burning is coming from the injection ecu, if you have 12 volts in the battery but no ignition lights the chances are the burning you have smelled is an electrical short circuit, which has caused the fuse to blow, in addition to the fuse located in the fuse box, check the starter relay, most models incorp a main fuse here, follow the poss red wire from the battery to locate the relay here the wire will split in to 2, check here for any fuses, secondly if you have no life at all in the battery not even enough to make a glimmer on the ignition light, the burning you have smelled could have come from the regulator rectifier in the bikes charging system check the rear of this unit for any burning to the silicone sealent, a fault with this could have blown a fuse also, it would be difficult to estimate a repaire cost without knowing the fault, try turning the ignition switch to the lock park position and check if rear light iluminates, this uses a separate ignition live, if this lights you would then know if you have suficiant power in the battery, to iluminate the ignition lite aand the fault would not be battery related,
Oct 27, 2010 | 2008 Suzuki GSX-R 600
Same Deal
check input circuit for blown input fuse. first make sure there is power at the outlet being plugged into. If there is power at outlet; then u have to check power input circuit starting from the line filter through bridge so on so forth. You may need the schematic.
Sep 15, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
Jul 12, 2009 | Music
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Word.
Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
PB10 Loud Hum and Crackle- LED Lights mixed Red/Green
Hello, Jesse. I doubt I can help, but there is at least one SIMPLE thing you can try - with maybe a 10% chance it wil return your unit to normal: Unplug the unit for 30 seconds, then plug it back in to a DIFFERENT outlet. Oh, yes - there are NO fuses or other "reset" devices. I'm sorry I couldn't offer you more help.
Jul 25, 2007 | JBL PB10 Subwoofer
Eiki LC-SE10 Projector Multimedia Projector Logo
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
