Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The plastic screws to remove the front face plate just turn and
Turn and the face plate never comes off
    Champion:
  • 246 Answers
I am not sure about your issue completely but I do know about a site that sells decorative covers and even stainless steel covers.
www.applianceart.com
They are worth checking out.
Posted on Feb 18, 2011
You do not turn them. It is a pin so use some pointey nose pliers to grab the little bar and pull it out. Push them in by hand when you finish but make sure the little bar that you grabbed with the pliers is vertical, just like you found it
Posted on Jul 21, 2009
When i power up gateway screen is black
Most likely, its a power supply issue. Have fixed a couple of these by replacing bad capacitors on the power supply board. A bad capacitor will have the top bulging, not flat on top as it should be. The way to get the monitor apart is a little tricky. You will need to remove the screws around the top, sides, and bottom, Do Not remove screws on back in the middle. These screws hold the metallic pan that houses the power supply it's self. I used an orange pealer from Tupperware to pray the front face plate away from the back. You can use a screwdriver, if you don't mind a little marring on the face plate plastic. It's not easy removing the front face piece, lots of interconnecting plastic locks all.around the front face plate. Using your pry tool and pulling (you'll need to use a little muscle) to get the front off. Once face plate is loose, you'll notice the screen is connected to the power supply, one in the middle usually can be pulled and disconnected using your hand. I suggest taking pictures before removing the other wires holding the screen to the power supply. At this point, the front plate is removed, and the screws holding the the screen have been removed, wires disconnected, and power supply in view. Best of luck
Nov 10, 2013 | Gateway FPD1960 19" Flat Panel LCD Monitor
Take off front cover of compaq tower
Remove the side cover or side case by removing the screws on the back. Once you have one side of the case removed, look down towards the front on the side of the metal case and you will see plastic catches or hinges from the front face plate. Push the hinges to release them from the metal frame then remove the front face plate.
Apr 11, 2012 | Computers & Internet
Need help to remove front plate on my suzuki aerio engine m15a
lay down in front of your car facing up under the front bumper, you will see 2 screws or knots left and right of the plate number plastic holder
Jan 09, 2011 | Suzuki Aerio Cars & Trucks
Unable to read disc
If your console is unable to read disc, then there seem to be a problem with the console, and the problem most likely is as a result of a bad laser/lens inside the console.
To replace the lens of the nitendo wii console, remove the two flip up panela on the side of the wii to reveal the black face plate with the controller ports and memory card slot.
Then remove the three screws located underneath the flip up panels using the fine phillips head screwdriver, then remove the black face plate.
Then remove the two tri wing screws located underneath the face plate. There are also two phillip head screws under the face plate but you can leave them in place.
Use a scalpel to peel off the two white stickers that are covering the screws located near the two front rubber feet on the bottom of the wii. This will reveal two black tri wing screws.
Use the scalpel to remove the two back ribber feet on the bottom of the wii, this will reveal two silver tri wing screws. Remove the two black tri wing screws and the two silver tri wing screws revealed on the bottom of the wii.
Use the scalpel to remove the rubber foot that is covering a screw in the top left corner at the back of the wii. Remove the screw using the fine phillip head screwdriver. Then use the scalpel to remove the white sticker covering the screw directly below the bar code on the back of the wii. Remove the screw with the tri wings screwdriver. Then use the fine phillip head screwdriver to remove the screw that is holding the battery cover in place on the back of the wii. This will reveal another screw that you can remove with the tri wing screwdriver.
Remove the front face plate of the wii, be careful because it is still attached to the console by a black and red wire. Disconnect the wires by lightly pulling on it. Remove the wii shell casing by gently lifting the separating it from the internal electronics of the console.
Remove the DVD drive by taking out the four corner screws using the large phillip head screwdriver then lift up the DVD drive and disconnect both power cable and ribbon cabble connecting it to the console.
Turn the disassembled console upside down, remove the two screws holding the DVD citcuit board in place, disconnect the three ribbon cable that are attached to the DVD circuit board, Use the tweezers to free the wires that are still connected to the circuit board from the plastic clips, Lift up the DVD circuit board and remove it from the way, then remove the lens case that is holding the lens ribbon cable in place.
Use the tweezers to remove the lens casing by lifting up on one side hooks that are holding it in place. This will reveal the laser lens unit, Which is held in place by two metal bars. Take out one of the metal bars by first removing the screws located next to it, and then gently lifting up on the plastic tab so you can slide it out.
Remove the laser lens unit and turn it over to reveal a white plastic part held in by a screw. Take out the screw so you can remove the white plastic part. You will need the part to install the replacement lens.
Attach the white plastic part from your old lens to your new lens using the same screw from the old unit. Place the new lens in the console and reassemble The DVD circuit board.
Remove the two solder points located on the lens ribbon by using a hot soldering iron.
Then reverse the process to reassemble the console.
Take care and good luck.
Hope this was helpful
Dec 03, 2010 | Nintendo Wii Console
How do I connect the wiring to my igniter switch on a patio 2 Tec grill?
Hi, You will need to remove the front face plate. There are 4 phillips head screws holding the face plate on - one in each corner. Remove the screws wth a #2 phillps head screw driver. Once the face plate is removed you will have access to the orange pilot assembly wire. Simple plug the orange wire into the igniter on the face plate. Bolt the face plate back in place.
With your gas supply off - turn your rotary ignter and make sure there is a spark present at the pilot assembly.
GrillTechs,LLC
customercare@grilltechs.com
Nov 06, 2010 | Tec Patio II Grill
How to change air filter for 2007 volkswagen jetta ,2.5
Hi, on the VW Jetta 2006 to 2009, the cabin filter is underneath the glove box so lay down on the floor and look under to see the 2 plastic screws. Access is gained by removing two plastic screws and gently pulling down a piece of foam insulation. Once the insulation is removed you can see the filter 8 inch long by 2 inch wide black plastic face plate. You must slide the face plate toward the passenger side door.
The face plate will now come off and the filter will still be inside and you will have to pull it down. Debris will come out onto the floor mat below. Insert the new cabin filter, put the face plate back up an slide toward he drivers side to lock in place. Replace the insulation, re-screw the 2 screws, and you're back in business with fresh air and clean hands besides!
Take care
Aug 10, 2010 | 2007 Volkswagen Jetta 2.5 Sedan
How do I open the case on a CTX desktop computer? All I see are the screws for the power supply.
Check the front face plate and you should be able to pull off the face plate and the screws should be located behind that.
Sep 12, 2009 | Computers & Internet
Front door plastic face plate of washer HE3t
yes. there aretorque screws around the inside frame remoive them and the 2 pieces will seperate. you can replace it then. be carefull if you remove the screws from the hinge the whole door will fall off. only six or so screws need to be removed
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
I cannot open my compaq evo d51s, any ideas?
I just removed one of these cases.
The silver face-plate is attached to the cover that you wish to remove. The black plastic just below the silver is a part of the base.
  • With the face of the computer towards you, place your thumbs on the black plastic below the face-plate.
  • Use your fingers to press into the side-buttons.
  • Using your thumbs to push against the base, pull the cover towards you.
Nov 20, 2008 | Compaq Evo D500 PC Desktop
How can I get the case of my Singer Featherweight II open?
To remove the cover of the Singer model 117 Featherweight II sewing machine:
Referring to the diagram below:
1.Remove the face plate by removing the single screw fastening it to the left end of the chassis.
2.
To make things easier, remove the presser foot (raise the presser foot and release the presser foot from its holder by pressing the black plastic foot release found at the rear of the foot holder, the foot will fall off.)
3.Remove the plastic see-thru slide plate that covers the bobbin. Remove the bobbin, and remove the two screws that secure the needle plate.Lift off the needle plate.Don't mess with the feed dog screws( Look closely at the" bobbin case assembly" and note how it is installed. The black thing you are looking at is the assembly. The chrome thing that looks like a hook is a fixed "bobbin case stop plate" , the case assembly fits under that and is supported by the hook race. Approximately 180 degrees from the fixed stop is a spring stop- note that the bobbin case assembly is free to rotate/ wiggle approximately 1/8" between these two points, and it is seated evenly in the hook race.Remember what you see so you can reinstall it later)Remove the bobbin case assembly with your fingers.
4.Remove the detachable tool case from the front of the machine by sliding it to the left.
5.The face cover is fastened to the chassis with four screws- two on the bottom which also pass through the bottom of the rear cover, one behind the face plate just above the lower thread guide, and one on the front of the machine behind the tool case. Remove the screws on the front and the left end, and loosen the two screws on the bottom ( if you are planning to remove the rear cover go ahead and remove the bottom screws completely.) There is no need to remove the screws that hold the auxiliary leg bar.
6.The screws are out- HOW DO I GET THE COVER OFF!?!
There is a hidden locking tab located just beneath the mylar seal that warns you to disconnect the machine before servicing and to close the cover before operating the machine. It is located just to the right of the needle plate and directly over the seam that separates the front and back covers. Don't remove the seal just slice it with a razor blade or utility knife right along the seam, make sure you cut all the way through the seal.
Working from the needle plate opening, take a medium sized flat-bladed screw driver and slide it under the rear cover just behind the seam (see photo) carefully twist the blade in a manner that both separates and lifts the rear cover off the front cover- it takes quite a bit of force and it will let loose with a loud snap. After the locking tab is loose the front cover is easily separated and lifted off the chassis.
unlocking the case:
a closeup of the tab on the front cover
7.The rear cover is held on by three screws. There is one through the back at the handle recess, and there are two screws accessible from the front after the front cover is removed. Lower the presser foot lever, pull the screws and the rear cover will come off easy. Good luck with your repairs.
Nov 10, 2008 | Singer Featherweight II 117
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
176 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
