A
Anonymous Posted on Jun 20, 2016
I really need a service tool to reset my canon MG5570, any one can help me?
I got my printer in trouble, i think i need a service tools to fix it. So if anyone can help me please send me a response about this issue. Big Thanks
Bill Boyd
Level 3:
Top Expert:
  • Canon Master 53,816 Answers
  • Posted on Jun 20, 2016
Bill Boyd
Canon Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949387
Points
172802
If you have got into trouble with the service of the equipment, forget the service tool and get in a technician as using the tool will not help you
How to download cannon service tool?
The Canon Service Tool is a software program used to reset or clear error messages on certain Canon printers. It is a proprietary software and can only be obtained through official Canon channels. Here are the steps to download the Canon Service Tool:
  1. Go to the Canon website and search for the service tool specific to your printer model.
  2. Click on the link to download the service tool.
  3. If prompted, enter the serial number of your printer to verify that it is compatible with the service tool.
  4. Follow the instructions provided to download and install the service tool on your computer.
It is important to note that the Canon Service Tool is a specialized tool and should only be used by trained professionals who have experience in servicing Canon printers. Using the tool improperly can cause damage to the printer or void its warranty. If you are not a trained professional, it is best to contact Canon customer support or take the printer to a certified technician for service.
1helpful
5answers
How do I fix error code 5b02 in Canon mx397?
When you clean the print heads, the ink has to go somewhere. This error code is, "waste pads are full". This is typically something that you take your printer to a service center for.
I did find some instructions for you, though:
How to Replace the Ink Absorber on Canon Printer eHow
2answers
Canon printer error code 006
you will have to replace the print head
2answers
Reset factory settings
  1. Hello please try the below steps to reset the printer:
    1. Hold down the "Resume" button on your Canon printer for one to two minutes, and then release the button. In some instances, this may reset the printer automatically.
    2. Unplug the power cable from the back of the Canon printer if the printer did not reset when you held down the "Resume" button. Hold the power button down and plug the power cable back into the Canon printer. Do not release the power button.
    3. Press the "Resume" button on the Canon printer two times and release the Canon's power button. The Canon printer resets to the factory settings and the ink level should appear full.
    If you will need more help you can download the service manual for canon ip6000d from the below link:
    http://goo.gl/gAqyP
    Thank you
20helpful
5answers
How to fix error 006 in canon service tool
how to solve it service tools code error 06?
3answers
Ink absorber almost full
Need to reset waste ink absober full.
Follow this step to reset waste ink absober full.
1> download iptool to reset waste ink absober full
Download here ----> Service tool 1
Service tool 2
After ypur download finish
> turn off your printer power switch
> open your printer cartridge door
> press and hold on/off button (never release)
> turn on printer power switch
> push your printer cartridge door switch with pen or anything can press door swith.
> then release on/off button
> close open door
> then press on/off button 1 more
now your printer is in normal mode( no orange led blinking)
Then you can use ip service tool to permanent reset waste ink absober full.
Hope this guide can help fix your problems
Extra download
Fixwasteinkabsoberflowip1000
1helpful
Cannon printer pixma ip 1600 ink absorber full
Dear khalid,
To fix this problem you need to reset waste ink counter of the printer by using General Tools for Canon ip1200 series (General Tools for ip1300 & 1800 series also works on this printer)
Perform following step to reset waste ink counter:
  • Enter service mode:
-Plug in power cable while holding power button.
-Press RESUME button twice
  • Connect USB cable (you may also connect USB cable before entering service mode, no problem).
  • Run General Tool
  • Select USB port
  • Click waste ink counter: Main & Platen
  • Turn off the printer then turn on and run your printer as usual.
I think it will be more helpful with picture enclose. For I cannot insert image more than 150 kb here, I suggest you to visit Canon Inkjet Printer Forum. I have discussed this topic before.
Please rate me.
Regards,
Ink absorber full
you have to reset the waste ink counter of the printer, for this download the software like IP tools, then reset it,
like it or not please rate it
1helpful
2answers
Canon Pixma 1P1600
printer driver canon PIXMA iP1600
old marine
old marine
ZJ Limited
ZJ Limited
