Question about Kohler Santa Rosa K-3323-0 White Compact Elongated Toilet with Toilet Seat
My toilet is a kohler low profile. There is not a
My toilet is a kohler low profile. There is not a place on the underside to remove or add nuts to the bottom of the bolts! I managed to hack off the old seat but now the new one wiggles around with no where to put nuts.
  • 5,660 Answers
Hacked off the old seat? You mean the closet flange that connects to the sewer pipe?
That's the part that has the bolts. They go up through the toilet base.
If you have just a straight sewer pipe now, you can connect a new closet flange to it.
1.Hardware stores sell a rubber sleeve. This sleeve fits over the cast iron, or copper, or plastic PVC pipe, and the new closet flange has a stem that fits down in the sleeve. There are two large hose clamps, that come with this rubber sleeve.
The rubber sleeve is an adapter. It adapts the 4 inch sewer pipe, down to the 3 inch stem on the closet flange. (Toilets are known as a 'Water Closet', hence the flange that the toilet bolts to, is a 'Closet Flange')
Whatever size of rubber sleeve you need to adapt two pipes together, they have it.
The new closet flange is made of PVC plastic.
(Poly Vinyl Chloride)
The flange itself is about 1/2 inch thick, and has provisions for bolts. (Use Toilet Bolts, and nuts)
Be sure the closet flange sits flush to the floor. The 1/2 inch thick rim of the flange, sits on top of the floor. The flange is then screwed to the floor with countersink head screws. The slots allow the bolts to just slip in.
IF, the flange Does Not sit level on the floor, and the area for the toilet base is not level, you need to make a flat, level surface!
Do Not half step this, or you'll have a toilet leak from now until the time you fix the floor!
Would appreciate it if you would rate my solution. If you have additional questions, state them by clicking on Additional Comments.
Posted on Jul 17, 2009
  • joecoolvette
    joecoolvette Jul 17, 2009
    Thought I would come back, and give you the Installation Instructions
    for the Kohler Santa Rosa one-piece toilet,
    http://www.us.kohler.com/onlinecatalog/p...
    This is a PDF file download. It may take up to 30 seconds before you see
    anything happening. It IS downloading, I assure you. You have Adobe Reader
    on your computer, and Adobe Reader uses PDF files.
How to tighten the seat
Tighten the seat by holding nuts on the underside of the bowl and taken a screwdriver and put it in the slots on top of seat under the caps that just pop off.
Jun 01, 2014 | Kohler K-4764-0 Zofa Soft Comfort...
Stuck kohler toilet seat
most modern toilet seats are removed by opening plastic tabs on the upper rear of the seat and turning the screws counter clockwise while holding the retaining nuts underneath the bowl.there has to be access and if not ,you could drill them out from the top using a small drill bit and slowly working your way up to bigger bits till the heads of the bolts are removed.
Nov 21, 2011 | Kohler Home
CANNOT UNTIGHTEN EITHER TOILET SEAT SCREWS - SO TIGHT WILL STRIP WITH ANY MORE PRESSURE. STRAIGHT SLOT - . ON A LOW PROFILE KOHLER . THERE IS NOT ACCESS TO THE OTHER END OF SCREWS EVERYTHING IS...
screws can be accessed thru tank..take a hacksaw blade only n cut from above (careful not to scratch where can be seen)..nuts will fall in tank..will have to reach for them thru tank.
Nov 19, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
I cant get the new flush valve on my kohler 3386 toilet to fit in the hole with the gasket. The foam gasket is quite thick. Is there a trick to doing this short of mutilating the thing?
The foam gasket stays on the inside of the tank, the only part that gets pushed through the hole is the hard plastic threaded part, then you add the rubber washer and the nut from underneath.
Jun 26, 2010 | Kohler - Toilet - One-piece - Gabrielle -...
How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Jun 01, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Feb 27, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Oct 30, 2009 | Kohler K-3384-2 San Raphael Elongated...
Can not remove toilet seat from Kohler Rialto
to access the nut remove the tank lid, then go down and forward, its there.
Jul 03, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
How do you replace the seat on a kohler lowboy?
There are two bolts that are under cover at the back of the seat. feel underneath for the nuts-pop the caps on top w/ a screwdriver. make sure you purchase the correct profile seat Elongated or standard..
Jan 20, 2009 | Kohler - Toilet Seat - Moondance -...
Kohler Santa Rosa K-3323-0 White Compact Elongated Toilet with Toilet Seat Logo
440 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
