I have a Sony STR DE-425 Receiver im working on. It has a loud crackling noise in all channels. It can be shocked into working again for a few seconds by switching inputs back and forth. The outputs and Bias resistors are fine. The crackling is present in the volume control and thusly in the preamp or input section. I checked the Voltage regulators but they are ok. I traced the noise back to a large smd IC with 60 leads. I am lost from here as I dont know whats in and out on that IC and I had to remove the board from unit to reach this area so I cannot perform voltage tests from here. Suggestions?
  • 1 more comment
  • Darrin  Thrun
    Darrin Thrun Jul 17, 2009
    Ill try that but would that cause the distortion to be tracable back before the control?
  • Darrin  Thrun
    Aslo on the crackling noise......it isnt just when adjusting volume......its constant and doesnt increase or decrease in sevarity when adjusting volume. It does increase in volume with the volume.
  • Darrin  Thrun
    Darrin Thrun Jul 18, 2009
    Thanks, Thats kinda what I figured, thats why I didnt accept the original solution offered.......Its a 60 pin SMD and I do not have a rework station. I hit it with freeze spray and it shocked it back to working but for only a second or so. Thanks for the help. Im a hobbiest thats self taught so I need an opinion when im stuck
  • 4,234 Answers
A couple of things to consider.
1) The fact that the volume of the noise is altered bythe volume control tells us that the source is BEFORE the volume control. This means either the pre-amp section or the switching IC. What is the number on the IC you have traced the problem to?
2) A semiconductor that is breaking down can generate this type of noise. Try to see if there is a pattern to when the problem occurs. For example, if you spray the ICs and transistors in the front end with freeze spray, does the problem go away?
Dan
Posted on Jul 17, 2009
    President:
  • 512 Answers
You have a dirty volume control. Either replace or take apart and spray with contact cleaner to get all the dust out. Easy fix, this is a common problen with volume controls. If you turn from left to right crackling is really bad. Results dirty volume knob.
Trying to get my 5.1 channel input to work on my sony str-445 receiver
Maybe it won't work because you have the inputs confused with the outputs.
Nov 08, 2013 | Sony STR-DE445 Receiver
I have a constant "crackling" noise in the left channel. I've replaced all 4 power transistors. The crackling is still there. Any clues?
Look for an open resistor in that channel. could be the large emitter resistor, or one of the low-ohm flame-proof resistors.
Jan 30, 2013 | Sony STR-DE197 Receiver
I have a Sony STR-DE 597 reciever. I have been using it fine for a few years with no problems and it sounded great. I turn the unit on recently and a message was displayed on the unit that said PROTECT....
Protect will usually show up if the receiver was turned up too loud to the point where the speakers will crackle, the receiver will switch to protect to not damage anything. Unplug it for about 30 seconds and check all the audio wiring in the back to make sure everything is plugged in good and tight and no loose cables or stray pieces of copper audio wire and plug it back in.
Aug 21, 2011 | Sony STR-DE595 Receiver
How can I use digital media port adapter TDM-iP50 with an older Sony STR DE 425 receiver's RCA inputs? Is there a conversion cable--dm port to RCA?
The dm port Can't you just pull the audio from the iPod from its analog headphone jack with an adapter? They're common and cheap.
Dec 29, 2010 | Sony STR-DE425 Receiver
My Sony STR-DA4400ES turns off when their is a loud noise on tv. How do I fix this problem
disconnect battery-or electric power for one hour.
watch a clock in the kitchen.
Nov 04, 2009 | Sony STR-DA4400ES 7.1 Channels Receiver
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Jan 20, 2008 | Sony STR-DE845 Receiver
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
Sony Receiver has little sound on radio stations
have you adjusted your sound settings while in listening to the radio mode?
Jul 30, 2007 | Sony STR-DE875 Receiver
Losing volume on channels
I am afraid not. That crackling is a component in one of the solid state amp circuits starting to fail. These are all soldered into the printed circuit board. This could be a difficult repair to find an intermittant component. Depending on how old the unit is and how much it cost will factor in on if you have it repaired or not. Rule of thumb is that if the unit is two to three years old and cost less the 200 to 300 bucks you should not invest more then 100 to 150 bucks into it. Good Luck
Mar 14, 2007 | Sony STR-DB840 Receiver
53 people viewed this question
 Grubhead
Grubhead
