Question about Motorola Mobility SLVR L7 Cellular Phone
Locked my phone and forgot the code
How can i use my computer to access my phone thru usb port in order to unlock phone. is there a free download i can get ?
  • 50 Answers
Re: locked my phone and forgot the code
You don't need a usb cable, type in :
and then hit ok.
Posted on Nov 18, 2007
0 characters
3 Points
HOW DO I UNLOCK MY LG MT375 CELL PHONE provides safest and easiest non-invasive way to unlock LG MT375 Lyric phone remotely. Both methods, with original USB cable or using generated code based on your phone's IMEI serial number will unlock your phone in no time. On you will find everything that is needed to unlock LG MT375 Lyric. Just place order and your phone will receive instructions regarding unlocking your phone remotelyServices we provide for LG MT375 Lyric are 100% safe. We're unlocking LG MT375 Lyric same way as manufacturer or carrier would do it so it has no negative effect on your device performance.For some new devices like LG MT375 Lyric you probably could try to unlock it using third party patched software or so but such methods may lead to disabling your phone and/or loosing your warranty. You may also find sites with free unlock code generators but in most cases those codes are for old devices and doesn't work correctly for newer devices. Such invalid codes may disable unlock by code methods. In such case unlocking your phone will require manual servicing (which is more expensive) or may even lock your phone permanently.Unlock time for LG MT375 Lyric varies from 0d to 3d, but usually takes 0d
Feb 16, 2012 | LG Cell Phones
I forgot my lock code and cant access my cell phone
You can get the Master reset code at here Unlocking4free at free of cost to reset the Phone from the security lock,You can get the master reset code for Nokia DCT and Alcatel phones there ...You need to specify the Brand and Model...
Sep 15, 2011 | Cell Phones
I need a unlock code for my n70 can you help me its urgent i have alot of phone numbers that i can't reach i have a nokia b70 ande can't get into it
If security code, use 12345 If network lock, follow the following steps.
You should have
- - DKU-5 USB cable with its drivers properly installed
- - BB5 unlocker by Dejan( you may google its all over the internet free)
- - And your phone
Unlock steps
1. - Connect DKU-5 usb cable to computer
2. - Check from >my computer properties > device manager> com ports to make sure that your DKU-5 “USB to Serial” com port in in range 1-9 if not, you can allocate it to that range.
3. - Open the downloaded “BB5 unlocker”, locate the file “bb5_unlocker.cfg” open it with note pad and edit the com port number to the one you chose in 2 above. Save and close.
4. - Still in BB5 unlocker folder, find “install.bat” and run it.
5. - At this stage, it should open the real unlocker tool and we are ready to unlock the phone.
6. - Connect your powered on BB5 phone( N70 in your case)
7. - Click READ PHONE
8. - Click MAKE LOG, log will be created
9. - Now run BB5 calc, it should say ok
10. - Now open c:\bb5_unlocker\BB%logunlocker
11. - Click UNLOCK SP, it should say “successfully unlocked”
12. - That’s it you are done and phone is successfully unlocked.!!!!!
Jan 02, 2010 | Nokia N70 Cellular Phone
I can not unlock my phone. i forgot my password. I tried the last four digits, called Verizon, and they told me to call my manufacturer-(samsung). I tried, but since my phone was locked, i could only...
You need to get a USB cable for your phone. I got one for under $3 delivered shopping on the net. You need to download & install the 4.4 Samsung USB Drivers, Google, they are free. You need to download, install & run a program called QXDM to get your MSL/SPC code. Then you download & install Samsung PSTLite v10004. Run that with your phone plugged into the USB port & turned on. Double click on your phone, then click on the PREPAID PHONE button, lower left, then READ ALL, at which point enter your code (you can try 998076 & see if its the same as mine was. After it is done reading your phone, you clock on the info button & you will get your two unlock codes for your phone. One of those will be the one you need.
I got this from another users post, kirbykirbykirby3, it is not mine, though I have added a little bit more information:
Here's how I find out the MSL/SPC from the U350, works with almost any phone.
QXDM, Connect it via Serial Port. (Com Port USB set to port 1, & 2)
Go to command output:
Type in Password "password 1945081520081106"
Without the quotes
Press Enter Key
then type in "requestnvitemread sec_code"
Without the quotes
Press Enter Key
there you go, security code right there.
You can also change anything you want... hehe.
Now boot up Samsung PSTLite, double click your phone U350, then click on 'Prepay' in the lower left corner, then click on read phone, then input the security code you got with QXDM for the 'Input MSL Code'. You can then click on info, settings, transfer, etc., make a backup of your address book, even edit it. I have not figured out how to get at the pictures with this method though. If you figure that one out, please post here as I am subscribed to this thread. Thank you.
Nov 11, 2009 | Samsung Smooth SCH-u350 Cell Phone
Forgot my security password
hello there. you need this software,
download it here.
then type the password to open
remove sim card from phone
connect usb cable, the one that came with your phone.
open software.
goto "Set write settings"
select the type of phone you have.
that being "SGH-E900"
then set the port number your phone is on.
this can be found by doing the following;
right click on the my computer icon.
select properties
then select hardware.
scroll through until you see ports
left click on this
you will see i description of the phone and the port number it is working on.
samsung SGH-E900(port 6)
close the hardware profiles and then select the port number as detailed
press the ok button.
scroll down and you will see an icon that is now highlighted saying Unlock.
left click on it.
the screen will go green and say passed.
Samsung SGH-E900 now unlocked.
Aug 04, 2008 | Samsung SGH-E900 Cellular Phone
Can't remember my phone lock code
If you have the USB cable for the phone you can read you phone code with setool2lite. Setool2lite is a free soft for customizing SE phones.
May 21, 2008 | Sony Ericsson W700i Cellular Phone
Forgot security code nokia 6288
I forgot my security code for nokia 6288 plz help me if you can
Apr 24, 2008 | Nokia 6288 Cellular Phone
Forgotten My Phone Lock Code
Ok, THIS WILL WORK! It worked on my W580i and it wasn't even supposed to. FIRST! Download (8.8MB) XS++ From HERE:
SECOND! No install. It just runs.
Make sure you have ALL drivers for YOUR phone. That should be under the bettery. Under model... or something like that. HERE!
Take your phone, turn it off. Start this program and click on connect. You'll have 30 seconds to plug your phone into your computer and HOLD C The entire time! (the delete button or 2). If connected, then click at the button: GDFS. There will be a phone lock reset to "0000". Click it. It will take no more than 45 seconds. I promise. Unplug your phone, and vuala! If your phone won't turn on, try pulling out the battery, putting it back and trying again. This program is also good for flashing phones, and putting flash menues on your phone. Also unlocking it and debranding it. GOOD LUCK!
Jan 03, 2008 | Sony Ericsson K800i Cellular Phone
The fastest way to unlock the code is to connect the phone to the USB socket and use password cracker to unlock the code. You can do this on your own.Try to find or borrow a USB cable to your phone and google search the software. If you take the phone to a mobile service repair shop they will do this for you for a little price.
Jun 27, 2007 | Samsung SCH-a670
Motorola Mobility SLVR L7 Cellular Phone Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
