Question about Raypak Pool & Spa
Pilot light does light but heater does not turn on
  • 864 Answers
Make sure the pipes are full of water. Check the thermostat to see if it is calling for heat. Make sure the thermostat is set to a temperature higher than the current temp of the water. If all those things are Ok then the gas valve coils may have to be replaced.
Posted on Jul 17, 2009
How do you light the pilot
Turn the gas knob to the pilot setting, press it in and hold it. You should hear gas escaping while in this position. Do not let more than about 10 seconds of gas out at one time as it may pool. Light the pilot while holding the gas knob down for a minute. Release the gas knob (the pilot flame should stay lit) and turn it to the ON position. To make sure the gas heater is working properly, turn up the thermostat and see if the heater heats up. How To Light The Pilot Light On Gas Heater
Oct 19, 2016 | Heating & Cooling
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
Rfn30ta gas heater dont stay lid
The most common problem with these types of heaters is dust build up in the pilot. If your pilot light is mostly a yellow flame you need to blow out the pilot of dust.
Turn off the unit. Remove the cover to expose the pilot. You should find two small holes about an inch or two below the tip of the pilot. Those holes are for mixing oxygen into the gas prior to it lighting. Blow those out with a can of compressed air and you may as well blow out the large burner also with the can of air. Wipe down everything with a damp cloth to remove additional dust.
Sometimes the pilot will light and stay lit, but when the burners turn on the flame moves slightly and pulls the flame away from the thermocouple. Either way this is a good idea to do every year or two on your heater.
Nov 11, 2013 | Heating & Cooling
Pilot light lights but goes out when I turn the main heater on / off switch
clean silver supply line to pilot generator sounds like cob webs not enough gas going to pilot make sure pilot generator is good also
Aug 24, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
When i unplug my rinnai heater does that turn off the pilot light?
If it's a Vent-free (Vent-less) heater, not it does not turn OFF the pilot light. If it is a Vented Heater, yes unplugging the heater will turn the pilot light OFF. If you want to turn the pilot off on either unit, the best way to do it is with the Gas Valve, Pilot Control Knob. Turn the knob from the ON position counterclockwise to the OFF position and the pilot flame will go out.
Hope this helped you.
Apr 09, 2011 | Heating & Cooling
Heater tuns off and pilot goes off
Feel the Outlet Water Pipe when the unit is burning and see if it is Getting very Hot, Should only be a little warmer than the water Inlet Pipe. If it is Getting really Hot, You may have a water flow problem and it may be going out on Hi Temp, Knocking out the Pilot..
Jun 25, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pilot lights but main burner dose not light when turned on
possibly a fowled thermocouple if the thermocouple doesn's sense the pilot flame then it will not send a signal to the gas valve telling it that its okay to open cause the pilot is lit.
Dec 28, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot light in water heater lights and then goes out
turn gas off the then back on then light
Jul 11, 2009 | Water Heaters
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pool & Spa Logo
162 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
