Question about HP PL4245N 42 in. HD-Ready Plasma Television
Same problem as rrobert4
Rrobert4
I am having the same problem and, also going to change the 1000UF caps. Did replacing the caps fix the issue? If that doesn't work I am just going to order the whole board but it's tricky cause I dont know if it's just the board or if there is another problem that caused this board to fail.
Website where to order board below
http://www.discount-merchant.com/We-provide-factory-original-parts-worldwide-p/1111876-n-fslash-a.htm
  • leguwan Jul 17, 2009
    So what do you suggest I do if I change the caps and it still doesn't work. There are about 4 leds on the main board when I turn on the tv 3 green light up after two seconds the relays click and then the green leds turn off and a red one turns on. Do you know what the red led is tring to indicate specifically, other then there is something wrong. Emial: leguwan@yahoo.com
    Regards,
    Leguwan
  • HP Master
  • 5,568 Answers
The power supplies in modern TV sets are absolutely miserable and probably half of all problems stem from power supply malfunctions, not caused by circuits beyond them.
BTW, the main filter caps that you are replacing don't fail that often. Mostly it is lower value, lower voltage caps in the supplies feedback path that keeps the supply regulated and running are at fault.
Posted on Jul 17, 2009
My 32" RCA model #
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Mar 25, 2011 | Televison & Video
Sp-R4212 Plasma no picture keeps changing channels when you go to the menu the menu keeps rolling won't stop if I unplug the set for a few days you can go to setup and get it to work I had Sears out to fix...
When the menu starts rolling, take the remote out of the room to see if it's the remote causing the problem.
if it's not, check for bad capacitors on the boards.
If you are handy with a soldering iron and can identify the bulging or leaking capacitors, an inexpensive handful of capacitors will likely fix you right up.
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
Mar 25, 2011 | Samsung HP-T4254 42 in. Plasma Television
Clicking sound, screen flickers - inverter board has been replaced with same results
There's a good chance you have failing electrolytic capacitors in the power section
Any caps that appear bulged at the top, or bulged/leaking at the bottom need to be replaced.
Mar 19, 2011 | Televison & Video
I have a sony klv-30mmr1 tv which now when I press the start/standby button It clicks and flashes red, and trys to go onto the setting where the blue light changesif I keep pressing the remote it seams to...
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
Mar 18, 2011 | Televison & Video
Tv screen goes black but sound remains after 30 minute of being on
Chances are it'll stay on for shorter and shorter periods of time.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
I found some great videos of the procedure (for different brand, but same issue) on youtube.
Mar 12, 2011 | Televison & Video
Not turning on at all
check your power supply. remove it then remove the metal plates on top of the psu. ill bet you find 2x 1000uf 35V ,4 x 1000uf 10V and 3x 670uf 35V capacitors that are swollen or leaking. if you replace the 1000uf caps it will work but if the 670uf caps are swollen as well its a good idea to replace them as well. the 1000uf capacitors can be bought at radio shack for around 10 dollars. you can use the 1000uf 35V caps for the 1000uf 10V caps if you cant find the 10V ones . the 35V caps are a little bit bigger but still work . you will need a good soldering iron (35-60 watts) and a good desoldering tool . easy to do if you know how to solder.
Jun 29, 2010 | TruTech PLV16320 Television
This is a power board going to the lamp of the DLP MITSUBISHI TV I HAVE THE NEW LAMP BUT THERE NO POWER GOING TO THE LAMP THE TV HAS POWER IT WON'T LIT THE SCREEN
there are bad capacitors on the power supply.
look for bulged caps
they look like this
replace the big ones on the power supply to fix the lamp issue
there are more bad ones inside typically on the dm and fmt boards
they are 1000uf - replace those ones with 680uf @ 16v caps
let me know if i can be of further assistance
Jun 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
RE: Replace 16v 1000uf
You can change the voltage rating to a higher one without compromizing the circuit. You can not lower the value however. In other words, using a 1000uF cap rated at 16V would be OK. The short answer is no, you can not use the extra caps you have unless you put 3 of them in series. (I doubt you have the space for that.)
Dan
May 29, 2008 | Mag Innovision LT776s 17" LCD Monitor
Sony MFM-HT75W 17in Multifunction Display
Hi, I was able to fix my set by changing only three out of the six capacitors between the heat sinks opposite the plug on the board. I noticed under a microscope the caps looked a little puffy, but not much, and I checked them with a capacitance meter, but they were in tolerance, but decided to change the three closes to the edge of the board with a 1000uf, 50v, 1000uf 25v and 1000uf, 50v with the one that is 25v going in the middle, I didn't have another 1000uf,50v for the middle one. (sometimes you gotta use what you got to get what you want) So I powered my set up and it stays on . I hope this helps. I may go back and replace all six with 1000uf, 50v, but the space in there is limited and those are some large caps. I will wait until the set acts up again before i do that. I am satisfied with it for now. Again I hope this will help with what you've got going on with yours.10_25_2011_8_27_53_pm.jpg
Nov 26, 2007 | Labtec LCS 1040 Computer Speakers
Problem with starting
read on a forum that changing out c316 1000uF will fix the problem, mine will not turn on now, seems to have gotten worse over time. I will change the capacitor from 1000uF 10v to 1000uF 16v.  Look at your capacitor, mine looks like its ready to blow.  Most other capacitors on the board are rated at 16 volts.  I will be changing out the cap. to see if it works.
Oct 05, 2007 | Philips DVP642 DVD Player
HP PL4245N 42 in. HD-Ready Plasma Television Logo
299 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
