Question about Dryers
The belt on the dryer tub is broken. What steps are required to replace the belt?
  • Dryers Master
  • 8,220 Answers
I have some pictures of several diferent type of dryer in various repair stages. take LOOK
Posted on Jul 17, 2009
Tub not turning
Likely a broken drive belt. A video below demonstrates taking apart and belt replacement on a typical LG dryer.
Feb 12, 2012 | LG DLE3733 Electric Dryer
Dryer wont spin but will heat up and blow air.
The belt that turns the tub is broken. Easy to replace. Any good handyman will know
by looking @ your type of dryer how to remove case and remove broken belt and replace it. hope this helps. I have replaced 2 in my time.
Oct 13, 2011 | Dryers
Drive belt is broken. How much disassemly is required to insert a new one around the drum?
usually you can remove the top panel and then on the inside you will see screws holding the front panel ...you will have to remove that.. if someone assist you they can hold tub up in place and keep it resting on back rollers while you gain access to under side of tub and route belt around tub and against tensioner to install new belt... a little time consuming but can be done by the do it yourselfer... wish you luck....
Feb 03, 2011 | Frigidaire GLEQ642A Electric Dryer
How do i fix the tub from not spinning
You did not say if it was broken or not...
If it is broken then it must be replaced.
If it is not broken, then it must have came off the pulley or the drum.
you have to pull the front of the dryer off and remove the drum to reinstall the belt on the pulley and the drum
Sep 25, 2009 | AEG Dryers
Belt on my Kenmore series 70 dryer broke. How do
broken belt......simple fix.......remove lint filter from top 2 screws remove.........insert screwdriver between top & front push down to pop top......1 screw on each side holding front on at top remove them....front will then pick up off the 2 remaining clips at the front bottom.....spin door around to the side belt should be laying in the bottom of the dryer or around the tub but broken.......hope this helps......check back.......
May 05, 2009 | Kenmore Dryers
Washer smoking
If the WASHER BELT is burnt or broken or the WASH TUB is not rotating properly.
FIRST CHECK THE BELT:
You can unplug the unit, remove the front panel of the washer and then slowly remove the belt. The replacement belt is easy to put back on. Finding a belt on the internet for under $10 is easy - just search for a belt with part number 134161100. Potentially the plastic pieces are from the damaged transmission. Replace the belt first to see if you can keep using the unit. If the transmission is damaged it is a bit expensive to replace and difficult to do yourself. I'll keep you posted if I have to do the same to my unit.
Remove and replace the washer belt (order part # 134161100 from google or ebay), arrived in two days and noticed busted plastic pieces and two semi-circular metal bearings that would have fit into the bearing.
IF REPLACING THE BELT DOES NOT WORK (read on)
Troubleshooting
Step 1: Keep the front panel of the unit off and run the unit in a normal wash mode. You can do this without filling up the wash tub with water by simply rotating the WASH dial to the proper setting (eg. RINSE). Be very careful as the moving parts could cause injury while the front panel of the washer is removed and the tub is turning.
Step 2: Watch to see if the belt is still slipping and the tub does not turn. If it rotates properly, then congratulations, you have fixed your problem with a new belt. If the belt still slips, ... proceed to step 3.
Step 3. Some web sites (and the user guide) say that the 'tension spring' may not be working. I don't believe this is the case. Upon closer inspection take a look at the 'transmission' which is the large metal part that rotates the tub. Unplug the unit and using your hands, see if you can rotate the tub simply by turning the transmission part. Turn the transmission in both directions. If you see that it gets STUCK from time to time, then the transmission needs to be replaced due to some worn bearings.
NOTE: From here you must first consider three things:
A. Do I want to get into a major repair with this washer, or simply purchase a new stack set?
B. Should I call a GE repair guy and have him replace the transmission?
C. Should I do it myself?
HOW TO FIX (If you chose "C" above):
FIX Prep Step 0. Gather a bunch of old towels around to clean up any water that spills
Step 1. Empty the wash basin and disconnect all external hoses, gas lines etc.
Step 2. Arrange the stack set so that you can lay it down on its back. Always good to have two people to do this step.
Step 3. Disconnect the tub basin springs and all electrical wires from the motor (this is easier to do while the unit is laying down; some channel lock pliers come in handy)
Step 4. You can stand the unit back up for this step. Slowly remove the tub basin from the unit, and position it upside down.
Step 5. Remove the transmission (requires standard socket set)
Step 6. Order the Transmission Assembly Kit online (I found mine at SEARS PARTS ONLINE, and when I called to check if they had it in stock, the customer service rep even gave me a code for 10% off the online order - not too shabby and makes me want to go back again. Great support service!)
Step 7. When the part arrives, re-assemble everything and test.
REORDER PARTS INFO
Tub Assembly Part Number: WH38X10014 (aka. GE part # 1603 on their 'break away' diagram)
Available on SearsPartsDirect.com
Note: The GE Parts people were unfortunately not helpful at all during this troubleshooting. In fact, when calling their support line I was told that they would not even sell me a transmission because I was not a certified repair man. The GE service rep was insistent that I could not find the transmission anywhere else except through them. Although they have nice diagrams of all the WSM2780 machine parts on their geappliance.com web site, don't look to them for any extended repair support.
You can contact me if you have any questions.
Thanks, Chringram
Jan 27, 2009 | GE WSM2780W Stacked Washer / Dryer
Broken belt on a Whirlpool dryer
Fix it yourself, and you do not need to remove the tub. Put the belt around the pulley and pull the tub towards the belt. You may have bought a belt that is too short. But upon a belt breaking they will stretch pretty bad also
Jan 13, 2009 | Amana ALW480DA Top Load Washer
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Jan 01, 2008 | LG DLG5988 Gas Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
