Question about Dometic Rooftop RV Air Conditioner
Air conditioner not working plugged in or on generator, heat not working either--nothing 2000 jayco designer
  • 1 more comment
  • wsagehom Jul 18, 2009
    Thanks,
    Tried all fuses, breaker on 120 VAC, no sounds no air no clicking...could it be relay switch? And where is that...thanks.
    It is a Jayco 2000, class C Designer, mini motorhome. The airconditioner is a "RVP". Last time we used it was at the end of camping season..Oct? Never had any problem. The thermostat is a heating and cooling one, I would have to look up the name. What about a relay switch?
  • wsagehom Jul 19, 2009
    ok-its a unit that has ducts throughout the camper in all the rooms. I do have the multimeter and tested the actual thermostat fuse it's fine. I don't thing there was any noise whatsoever from the fan but I'll try again. I do have all the model numbers and will post them later. Thank you so much for the help it's much appreciated!
  • Dometic Master
  • 6,674 Answers
If you have AC hydro for sure to unit, perhaps a fuse in the 12 volt DC panel has blown, or in thermostat itself. Hear any clicking at AC unit when turned on? If not, check all your fuses in 12 volt DC panel. Check breaker didn't trip also on 120 VAC.
Posted on Jul 18, 2009
  • Mike Butler
    Mike Butler Jul 18, 2009
    When was last time it worked? It says it's a dometic correct? And what does your thermostat look like, model if you have it.
  • Mike Butler
    O.K. so it's a Coleman. Will need to know what ceiling assy you have as well, ducted or non ducted. Non ducted blow cold air out ends at ceiling, ducted blows out all ducts in all rooms in ceiling.If you just remove filters, you should be able to see model numbers. There will be one set of numbers on ceiling assy itself & another sticker on base of upper unit that will start with , 7330,8330, 9330, 9530, then a letter or 2 then about 3 more numbers. The reason I need that is because they are wired according to models. With no clicking at all going on, I don't want to start guessing. When I get this info, I can tell you better/safer what to do. Do you have a multimeter by chance & know how to use it? If you listen real close & turn it on to fan only, can you hear a faint "Hum" from AC?
When we plug our generator 2000 SI Honda to 5th wheel it over loads to run the air conditioner why does this happen
It to small needs to be 3500 or better that compress on ac pulls a lot of ampege wen it kicks on
Feb 10, 2015 | Heating & Cooling
Can I run a daikin mini split heat pump 3MXS24JVJU with a generaton
It depends on the SIZE of the generator. If your generator is designed to supply 240-volt A/C and handle the FLA (Full Load Amps) rating of your Indoor and Outdoor units, then, YES, of course you can run it with a generator.
Aug 26, 2014 | Cfm Daikin R410a Split System Air...
How does it matter which direction condensor fan turns
Yes. The fan is designed to draw air through the condensing unit to expel heat generated by compression and heat exchange in the refrigeration system. If the fan is running the wrong way, heat will not be disipated correctly and the unit will not operate efficiently. You could end up damaging the system.
Aug 18, 2014 | Dometic Rooftop RV Air Conditioner
I HAVE DOMETIC DUO-THERM PENGUIN ROOF AIR CONDITIONING ON RV. THE UNIT WILL RUN WHEN PLUGGED INTO ELECTRICITY BUT WHEN GENERATOR POWERED THE AC UNIT KILLS THE GENERATOR ENGINE. WHAT COULD IT BE?
What size & type generator? On start up the AC unit can draw as much as 17-18 amps in some cases, and if your generator is not designed for a quick draw like that it will die.
Jan 25, 2013 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
390 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
