Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
How do I separate a stacked washer/dryer combo unit?
Is it possible to separate the washer from the dryer in a stacked Combo unit? We need to get it out of the basement and it may be too big unless we can separate it into two pieces... Thanks for any help...
  • 4 Answers
Tried this before and is a major undertaking. The front angle panel has to be removed before you can access the rear panel, and then all of the electrical connections need to be traced and disconnected. This is a job for a tech and not recommended. I would suggest you measure, and then measure again and find a way to remove it in one piece, maybe even out a window if one is big enough.
Posted on Jul 20, 2009
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
Frigidaire Washer Dryer Combo (Stacked) We had to have the power shut off to our house. Now that it is turned back on, our washer dryer combo won't start.
Thank you for your inquiry, Caroline!
From the information you have provided your Frigidaire laundry center is no longer working. I understand that you had to shut off power to your house and now your laundry center is not coming on. It sounds like you could have a possible short within your timer. I would recommend performing a reset on your laundry center and you can do that by unplugging the power cord for roughly ten minutes. If you continue to have issues with your dishwasher can you provide me with your model number? In order to locate your model number you can find the serial tag and that should be located on the inside wall of your dishwasher. I look forward to assisting you further. -OOS
Mar 23, 2015 | Koolatron 1.7cuft Thermoelectric Fridge
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
Jul 13, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Separating a washer dryer combo
This is a one piece unit. It does not come apart. Use and appliance hand truck with straps to secure. You will need at least 2 people to get unit out, heavy. I used to deliver appliances.
Jul 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Combo Model 417.98702890
There is an EXTERNAL fuse on the back of the unit.
Service manual is inside the machine's shell in plastic.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
1,028 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
