I have a Hitachi, 42 in. plasma ultravision and this morning I could not turn the tv on. No power.
    President:
  • 632 Answers
Check the branch circuit of your convenience outlet..the circuit breaker may have tripped..try to connect other appliance to the outlet where your TV is connected..this is to ensure there's power in it..if you are certain then that there's indeed power from the outlet you are sure that the TV is not working..check TV fuse and replace if blown..check resistance between the plug terminals after fuse replacement..if resistance is low, change voltage dependent resistor (VDR) with same value..it is a disk type resistor that looks like a big ceramic capacitor located just after the fuse..either blue,black or red.blown fuse may be due to power surge during the night..
Posted on Jul 19, 2009
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
May 23, 2011 | Hitachi UltraVision 42HDS52 42 in....
Blue vertical line appearing / flashing on Hitachi ultravision plasma tv model number 42HDS52A ??
So the lines goes up and down or is it across from side to side, if it's side to side then it's your terminal power board.
Jan 04, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
Hitachi Ultravision won't turn on
it is the power board in the tv hase some bad capasators in it but can cost some money to fix if unsher how to do it on your own if you live in central new york i do have my own shop and im cheep but i can not warenty any thing but i can help 315-280-0508 storm electronics ask for corey
Aug 04, 2009 | Hitachi UltraVision 42HDS52 42 in....
Tv won't turn on
ether the lamp needs to be replaced or you have a bad capasotor on your power board
May 28, 2009 | Hitachi UltraVision 42HDS52 42 in....
Vertical Green Bar 3" wide on the right side of my 42" plasma
My thought is that it is an Intergrated Circuit (IC). But it has been brought to my attention that it may be as simple as adding a "ground adapter" to the plug of the TV. If after you try changing out the ground adapter and it doesn't work, try "power cycling" your TV. (unpluging it... Waiting 30 seconds, then plug it back in.) If that fails, contact Hitachi so they can recommend an authorized service center in your area. Hope this helps. Good luck, KMarshall!
May 25, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Sound Problems with Hitachi 42HDS69
Probably the main board, audio processer blown. about 300.00 to repair. A service tech told me this and the repair worked.
Feb 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi pd7200 42" plasma
unplug. leave off for a few minutes. small chance it will reset.
also, it might have lost its input setting and is no longer looking at the input you send the source signal to.
good luck
mark
Dec 02, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Electro Med Services...
