TruTech T650-DR DVD Recorder
Problem for TruTech T650-DR DVD Recorder
How do I record TV
By bruegg1997 on Jul 17, 2009
How do I record TV to DVD? I have a Trutech T650- DR. I can not get the recorder to identify a signal. I have Charter cable.
Comments:
Jul 18, 2009
- Are you kidding me? If it was that easy, I wouldn't have asked and paid for help. When I press "Record", I get a message that says r00t on my machine. What does that mean? I went into the Wizard and tried to select a source to record from, but every source: TV channel, AV, etc. gives me the "no signal" response. Do I need to do anything with the initial menu set-up? If so, work me through it. Thank you for a prompt response.
Solution #1
posted on Jul 17, 2009
Not Rated)
all-guru
Rank: Guru
Rating: 85%, 273 votes
Step 1. Set the recording timer on your DVD recorder to record the chosen program when it comes on, or wait for the show to start and do the recording manually. Place a blank, recordable disc in the tray of your DVD recorder and close the tray.
Step 2. Make notes of where you'd like to insert chapter stops, being ready to skip over commercials and edit them from the program. It helps to have a general idea in advance where to insert chapter breaks. For an hour-long program, chapter breaks every 10 to 15 minutes are convenient when reviewing the program later.
Step 3. Press the "Record" button on the DVD recorder to commence burning the program to DVD. Use the Pause and Edit controls of the DVD recorder to eliminate commercials and create chapter stops on the DVD for easy browsing later. Place the recorded disc in a protective sleeve or case and label it for easy identification later.
Good Luck!!
Thanks
Solution #2
posted on Jul 18, 2009
Not Rated)
micromatikal
Rank: Wiz
Rating: 84%, 251 votes
Hello there, when you say you can't get it to select a signal, does it show the signal on the screen? Do you have your direc tv running through the box? This is a pretty difficult problem to describe all the possible scenarios for via posts... You need to make sure you have output from the directv box going to the input on the dvd recorder. Select that as your source, put in a blank dvd, and it should be as simple as hitting record while that input source is playing something.
r00t usually is indicating that you are on the root of the disc, otherwise not certain what it would be referring to. If it does not record to DVD and you have the input comeing from your directv box, and that input selected as the source, then there is something wrong with the unit.
Thanks
Tim
Popular Solutions for TruTech T650-DR DVD Recorder
Questions and Unsolved Problems for TruTech T650-DR DVD Recorder
Do you recommend TruTech T650-DR DVD Recorder?
Answer
Answer
help connecting to directv hd receiver
Answer
no sound when you record. iam now trying to record just from from the tv.
Answer
can i program my cable remote to run my trutech dvd player model #ts9300? i bought this dvd player... (More)
Answer
Someone gave me this product, but they coulod not find the manual! They took it out of the box and... (More)
Describe your DVD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in , ME
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
