Question about Labtec Optical PS2 911544-0914 Mouse
Mouse problem. Hi, I had a targus mouse that stopped working, so I went out and bought a labtec wireless optical mouse.800 m/n: m-rby127. I've inserted the disc, the computer has created the necessary file and all that jazz saved onto my laptop. When I went the control panel and clicked on mouse, my laptop tells me " unable to connect to the synaptics pointing device driver?" the end result is the mouse still does'nt work. I need your assistance please.
  • 1 more comment
  • spacerguy
    spacerguy Nov 19, 2007
    My touchpad works but none of the USB ports are accepting peripheral mice, interestingly a point I forgot my laptop told me a few days ago that Windows(I think, I have xp) does not recognise the peripheral device in port xxx. It was refering to the targus plug in mouse. But now I've purchased a Labtec wireless optical mouse 800. I've loaded the Labtec file via disc maybe it needs me to open the file??
  • spacerguy
    spacerguy Nov 21, 2007
    Thanks accordianman for your solutions, they got me thinking. I borrowed a dell mouse and plugged it in and it actually worked! So much for my new mouse. It must be a dud.
  • Anonymous Feb 16, 2008
    I replaced my hp wired rubber ball mouse with a Labtec 800 on the serial port and then could not control the mouse pointer half the time. It flys off the screen and jumps around on its own then settles down and is controllable for a short while then again goes ballistic. Im running Vista home premium which has most drivers onboard but thinking the disk that came with the mouse might have a better driver, I installed it. What a mistake... the mouse pointer then locked in the middle of the screen and I lost all control of my computer. Using the window key, I was able to open my control panel and delete this crappy program. The pointer was still locked but it would work from the usb port. It still randomly jumps off the screen. Moving the receiver around has no effect on the overall operation. Hooked it up on my old XP prof computer and got same results. Im ready to chuck this piece of crap and use my wired mouse unless there is a positive fix available.
  • 979 Answers
Does your onboard mouse still work? This will help point me in the correct direction for your fix.....accordianman
Posted on Nov 19, 2007
  • Michael Borelli Nov 20, 2007
    Ahah! Go to device mgr in your desktop and make sure the port is "always on". Windows XP has the port disable if there is no activity after about 10 minutes...accordianman
    Control Panel>Performance and Maint>System>Hardware>Device Mgr>Universal Serial Buss controllers>. Select the proper parameters there and that Should be it. (If that's my guess!)... accordianman
It has a very weak red lightmy mouse stopped working
It sounds, to me, like the batteries need replacing. There is a diagram in the user manual here:
Oct 29, 2010 | Targus Wireless Optical Notebook Mouse...
My mouse stopped working, it does move once in awhile. I don't see any batteries. Is it time for a new one? Any suggestions. It is only 6 months old.
The battery compartment can be accessed in this mouse (Targus pawm002e) by sliding off the top cover of the mouse.
It's not located on the bottom of the mouse, as usual, so it may be hard to figure out at first.
Good luck, and please come back with a rating/testimonial if helped :)
Jul 24, 2010 | Targus Wireless Mini Optical Mouse
How do I insert battery
on the bottom there is a small indentation which you can use your finger or thumb or small screwdriver to slide open revealing a space where the batteries are. Open and replace and close.
Please rate this answer. Thank you.
Mar 28, 2010 | Targus Wireless Stow-N-Go Optical Laptop...
How do i install a targus mouse
Depending on your OS, just use the software provided and then place the batteries in the device and connect it as directed.
Sep 21, 2009 | Targus Wireless Optical Notebook Mouse...
My S.O. Vista x32 doesn't recognize my mouse optical labtec 800
you can check your usb driver
it's work or not
you can go to control panel after that system device and hardware
and check proper install or not
Sep 20, 2009 | Labtec 800 Mouse
Targus wireless mouse not working
I think my mouse is not moving because one usb is missing. I
have trouble find one usb that can help move my mouse.
Aug 24, 2008 | Targus Wireless Optical Notebook Mouse...
Help mouse problem
Click Here to download the User's Manual. It may just be going into sleep mode.
The Targus Wireless Optical Notebook Mouse features an ergonomic design with built-in power management allowing for travel or everyday desktop use. The physical on/off switch, combined with a touch sensor for sleep mode, enable optimized power management capabilities. The thumb-size USB receiver with 90-degree swivel provides flexibility in limited workspace. The mouse features sensitive optical technology for increased accuracy and ease of use.
Jul 27, 2008 | Targus Wireless Optical Notebook Mouse...
Labtec wireless desktop.
Could be radio interference from somewhere. I tracked my similar mouse problem down to emissions from the ethernet adapter that connects over the house mains wiring. Try the using the mouse close to the receiver, if it works ok interference is likely.
Jan 24, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Labtec Optical PS2 911544-0914 Mouse Logo
438 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
