Question about American Standard Home
Kitchen sink leak
How do i tighten kitchen facet
  • pallen77 Jul 21, 2009
    Hey Steve thanks for your quick response sir about my Dear Mothers sink! Its a 15yr old sigle sprout sink AMER.Stand.! and it leackes around the top of here 6inch base and also leak down the bottom! I am having a time trying to tighten it from the botom for it hase like a horseshoe shape washer under the sink!\r\n
    I appreciate your time and knowledge Steve!
    The other problen is that her (mother) the other day tried out her Central air and when I turned on her thermostate it would only come on at 20cel. when i bump it up to 85 or more over it shuts down! Now she just has a standard old time therm (mercury read with a single yellow) wire now the mercury looks like its sloping downwards as apposed too being level? Can u haep me on this one 2?
    Have a nice day!
    Pablo & Ma
    Bro Steve, \r\n
    Firsttly I like u too know that your solutions for are sink is now fixed by changing the 3 washers!TY
    Now for the heat thermastate, yes it also runs Ma's furnce and insted of just a yellow lead that I mentioned it has 2others Blue and white leads hooked up to 1 post and a mercury slider up top!
    Now you mentioned about cleaning the Thermo No, Ma has had this unit for 3yrs (no clean)!
    I will patently awaite your FINE EXPERTIZE on things! UR THE MAN!
    Many Thanks again Steve!
    P&Ma
    Scholar:
  • 83 Answers
Hi
Where is it leaking from? is it a single spout/mixer tap?
Please verify, and i should be able to help you
Thanks
Steve :o)
Posted on Jul 17, 2009
  • 1 more comment
  • Steve Smith
    Steve Smith Jul 21, 2009
    Hi Pablo & Ma,
    It sounds like the 'o' rings are gone on the tap, ignore the horseshoe shaped washer as this isn't sealing water it is actually used to secure the tap to the sink.
    If you have tightened the tap to stop it leaking, isolate the water supplies, and loosen the parts you have tightened on the spout, take it apart and inspect the washers/ 'o' rings. take them out and go to a plumbing merchants and get replacements. If this isn't possible try this....
    You can buy a repair tape (its called P.T.F.E. in the UK) it's white and will repair most water leaks,also purchase some silicone grease both are ok on potable water (drinking water). Wrap the PTFE around the 'o'ring on the tap, then lightly coat it with silicone grease.
    This should resolve your problem.
    Let me know how you get on
    Steve :o)
  • Steve Smith
    As for the Gas Warm air,let me ask a few questions;
    Is it a fan assisted warm air heater?
    Has it been serviced/cleaned recently?
    I can solve this with a few questions being answered
    Thanks
    Steve :o)
  • Steve Smith
    Steve Smith Jul 22, 2009
    Hi P & Ma!
    I'm so glad you sorted your tap out.....WELL DONE TO YOU! :)
    As for the heating, the unit should be cleaned every year! If this isn't done it can cause carbon monoxide to leak into your house, this can potentially kill you! :(
    I don't want this to happen to you or your Ma! please get this serviced/cleaned by a qualified gas engineer, i suspect because it hasn't been cleaned/serviced that a thermistor in the unit is dusty, this is giving false readings and making the ubit shut down.
    Please get it serviced Pablo.
    I hope this helps.
    Steve :o)
    P.s. let me know how it goes, and if i can help with anything else, just ask!
    Take care.
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking.
If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
May 04, 2014 | Kohler Model 10430: Fort® Single-control...
Wiggling Goose Neck
There could be loose hardware inside at the base of the goose neck. You will have to remove your carefully installed faucet and take a look inside to find out.
Nov 13, 2013 | Globe Union Glacier Bay 8 In Double Handle...
Leaking kitchen facet by delta
Great design! Even I think that it's a must have kitchen appliance specially for modular kitchen users.
Aug 24, 2013 | Delta Model 470: Signature Kitchen...
Kitchen sink sprayer leaks down the hose to under the sink
sounds like its either just not tightened enough or you need to buy a rubber washer to put in it. Right at the bottom of the sprayer.
Feb 29, 2012 | Plumbing
I have a pegasus sink and I'm having a hard time getting the drain not to leak. The base of sink if thicker in the front than the back so when we tighten the drain it will only tighten so much in the back...
You need to take it off copletly and clean it then take 100% clear silicon put it down on the sink base and on th e bottem lipe of the basket strainer tighten down till silicon sqeezes out top of sink wipe with paper towel and wate 24 hours befor use.
Jan 21, 2011 | Pegasus Technologies Pegasus Kitchen Sink...
The sink drain leaks
Sounds like plumbers putty un drain flange to sink may need to be replaced or strainer may need to be tighten up a little to see if that stops the leak.
May 05, 2010 | Plumbing
The pullout spout leaks
pull out the spray part and tighten the nut around the hose or take it loose and replace the washer
Jun 28, 2009 | Kohler K-15160-7 Coralais single-control...
My Danze Anu Kitchen Faucet
Sounds like you have hard water.  You need to change the inside of the facet.  before doing anything make sure you CAN get the parts for you facet.   Danze are not very expencive you might just get a new facet.  If this is a hard water problem you might want to buy a moen facet with a life time warrinty.  More money but free replacement parts.
Apr 04, 2009 | Plumbing
Kitchen sink drain loose
You can probably tighten it from the bottom. But first, get a little plumber putty from the hardware store and put it around the seal from the topside of the sink. As you tighten it down, it will squeeze out a bit, but that is okay. Good luck!
Mar 25, 2009 | Plumbing
How To Connect Sinks Drain
No matter what type of sink you purchase, the drain and water-supply connections are generally installed in the same way. Hand-tighten a female adapter onto the drain stub-out at the wall. Slide slip nuts onto the drain arm and the sink's tailpiece. Fit a P-trap in place and tighten the slip nuts by hand. Connect flexible water-supply tubes onto the faucet's tailpieces, and route them to the shut-off valves. Tighten coupling nuts with an adjustable wrench. Remove the faucet aerator, turn on the water, check for leaks at the shutoff valves, and then turn on the faucet to check for leaks in the drain assembly. Replace the aerator.
Aug 27, 2008 | Blanco 510-879 Single Bowl Undermount...
Home Logo
228 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
