Question about Whirlpool GU2400XTP Built-in Dishwasher
The power button is flashing. we cannot operate the dishwasher
I just came to this website and received an answer to a similiar question. Try running the diagnostic program, the service sheet is under the toe kick at the front of the dishwasher. Running the diagnostic program takes approximately 16 mins and will give you good information.
Posted on Jul 21, 2009
How do I restart my double flashing dishwasher?
What kind of dishwasher are you talking about? What's the model number, how old is it? This information is important as not all dishwashers work and operate the same. I need more information to assist you.
Thanks
Apr 18, 2016 | Dishwashers
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Dishwasher does not work - flashing start button
Brandt dishwasher. Code D06 appears!
Jun 17, 2013 | Dishwashers
My kenmore dishwasher 665.17052400 clean light is flashing 7 times. I cannot locate the tech sheet to find out what is wrong. I have reset the panel and it will run then blink again after 15 mins or so. ...
Reset the Control Panel
A power surge or outage may cause the "Clean" light to flash continuously after power is restored. Pressing the buttons on the panel in order and within 5 seconds resets the control panel and turns off the flashing light. The buttons must be pressed in the following order: "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash." After pressing the buttons, your Kenmore dishwasher will begin a short, 12 minute test cycle and reset the control panel.
Door Switch
A broken door switch can keep a Kenmore dishwasher from operating correctly, resulting in a flashing "Clean" light. Testing the door switch requires removing the door panel to access the control panel holding the switch in place. A continuity tester can determine if the switch has failed once you remove it from the door. Replace the switch if it fails to pass the continuity test. Make sure to disconnect the electricity to the dishwasher before accessing the switch.
I hope this helps.
Jan 10, 2018 | Kenmore Dishwashers
The "Clean" button keeps flashing...
If the clean button is flashing all the time then there is a problem with the button itself. The unit will not operate until the problem is fixed.
Might need the dishwasher make and model to assess the problem better.
Jan 29, 2011 | Dishwashers
We have the Whirlpool dishwasher ,Model: ADG6 955. used it smoothly last night but this afternoon, it just will not start up. The green 'START" button keeps flashing and the dishwasher just does not...
Try turning off power to the dishwasher completely by either unplugging it or turning off the circuit breaker for a few minutes, then power it back up. Sometimes this will reset it.
Oct 11, 2017 | Whirlpool Dishwashers
Whirlpool Dishwasher Model GU2500XTPS1 Light on soak/scour button flashes on and off. Dishwasher will not run.
there s atechsheet / troubleshooter behind you lower kickplate assy-- this was taken from there
PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted
circuit(s) in keypad.
See Checking Keypad Operation, page 1. Shorted circuits or
connections on the control
that read the keys .check/replace keypad
2. Check/replace control
Nov 03, 2008 | Whirlpool Dishwashers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
265 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
