Question about HP DesignJet 450c InkJet Printer
Prints 25% of sheet, and then trims it off while still continuing to print. Then the "cartridge", "data", and "media" lights come on and stay on.
    Problem Solver:
  • 10 Answers
***if you experience problems pressing PRINT, most of times the cause is the driver.
Please look here
www.plotterdriver.it
CAD & Prints
Posted on Oct 10, 2009
Prints total black sheet of paper
If there are no indicator lights, it's probably a defective cartridge.
Apr 23, 2016 | HP LaserJet 1020 Printer
Explain the report that prints when aligning cartrige
older copiers when aligning the printer heads used to print out a series of various stokes ranging from light grey to black as well as colored strokes
It was up to you to set the middle of the range
Later models print out a pattern sheet which you then photocopy back into the printer and it automatically does the aligning for you
so after you install a new cartridge and get the align now message when that sheet is printed , place it face down as if you are scanning a document and press continue and wait for it to finish
Oct 05, 2015 | Office Equipment & Supplies
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
Poor black print quality black prints greenish grey
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
  3. Verify that only KODAK branded ink cartridges are installed.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door, then make the same print.
If issue still continues:
  1. Verify that inkjet paper is loaded in the paper tray.
  2. Press and hold Cancel + Copy/Resume simultaneously until the On/Off light flashes green. The On/Off light continues to flash during the cleaning procedure.
  3. When the On/Off light glows a steady green, press and hold Scan + Copy/Resume simultaneously until the On/Off light flashes, then wait for the demo sheet to print.
the printhead for your printer is in need of replacement. Contact Kodak
Best of Luck
Nov 16, 2009 | Office Equipment & Supplies
Yellow light keeps on blinking
one of the cartridges is dead and must be changed. buy new one and the problem will be solved.
Aug 02, 2009 | HP DeskJet 640c InkJet Printer
Easyshare 5500 prints very light even after cartridge replaced
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free. I hope this helps.
Jan 27, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Menu letters in tool button
The letters refer to the following:
A = Prints the nozzle check pattern
H = Cleans the fine cartridge
Y = Fine cartridge deep cleaning
P = prints head alignment sheet
L = prints the fine cartridge alignment sheet
U = Scans and then aligns the sheet you printed under the L option
All in the user manual in Chapter 9. Download a copy here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368
Nov 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Keep getting message Press Enter to Align Cartridges
Try the following button sequence on the front panel of the printer :
Press and hold the Setup, button, and then press Options (or Copy Options).
Oct 25, 2008 | HP PSC 950 All-In-One InkJet Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP DesignJet 450c InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
