Question about Cadence Exercise & Fitness
Whilst jogging hands free the treadmill belt sticks why would this happen
  • 11 Answers
You need to lubricate the belt every 6 months or so. to do this lift up the belt and squirt some lubricant onto the belt board(not the rollers), do this on the left and right hand side.
you may also need to tighten the belt. this is normally done with an allen key, look at the end of the treadmill as if you were to walk onto it, and there should be a plastic cover on each side. look in here and you should see an allen key type bolt. turn each bolt one full turn. this will tighten the belt and stop it sticking.
Posted on Jul 25, 2009
    New Friend:
  • 64 Answers
If lube and adjusting the walking belt doesn't help. Try adjusting the drive belt. This the belt under the hood that connects motor to drive roller. If you still have problem you probably need a new belt and deck.
Posted on Jul 27, 2009
Belt keeps slipping on treadmill
Adjusting Tension on a Treadmill Running Belt It is necessary to properly tension a treadmill belt when it is replaced. After time, a belt can stretch and may begin to slip. When this happens, it is necessary to adjust the tension of the running belt to stop it from slipping. Manufacturers of treadmills generally agree on one of three procedures for how to tension a treadmill running belt.
  1. Adjust for no slippage of the treadmill walking belt on the front roller (Often referred to as the "Stomp Test")
    1. This procedure works well for a previously installed belt that is now slipping.
    2. Underside of belt should be free of any glazing/wax buildup.
    3. Rollers must also be free of wax buildup.
    4. Be sure belt tracking/centering is correct before proceeding.
    5. The most popular speed for this adjustment is 2mph to 3mph.
    6. Try to slow the belt by applying pressure with your foot against the belt movement while grasping the handrails. If the running belt slow, slips or stops (and the front roller does not) adjust BOTH adjustment bolts 1/4 turn clockwise. Test again and repeat adjustment if necessary.
  2. This procedure requires two belt gauges or calipers
    1. This procedure works well when installing a new belt.
    2. This procedure requires you to stretch the belt. Depending on the manufacturer*, this varies between .4 and .6 percent. A dial on the gauge or caliper will indicate the amount of stretch. *Consult the owner/service manual for proper tension.
    3. If you are working on a previously tensioned belt you will need to release the tension before attaching the gauges or calipers.
  3. Gauges or Calipers unavailable
    1. Release the tension on the belt.
    2. Using a yard stick or tape measure, place two marks on the left and right edges of the belt and deck 36 inches apart (or 50 inches if you prefer).
    3. Adjust the left and right tensioning bolts until both sides measure 36 3/16 inches (or 50 1/4). This is equal to .5% of stretch.
    4. Test for proper tracking and tension, adjust if necessary.
How to Tension Treadmill Walking Belt that Slips
Apr 01, 2014 | Life Fitness 91Ti Treadmill
Belt sticks when running and briskly walking
Walking belt or drive belt loose. If you get noise while this is happening your front roller is likely bad.
Dec 25, 2013 | Proform Xp 550s Treadmill Walking Belt
Have ProForm 495Pi cooling breeze treadmill. If I set it on 6mph and start to jog it stops abruptly
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time.
Jun 09, 2010 | New Balance 1400 Treadmill
Belt is sticking
You may be too tight, or has already accumulated too much dirt from the deck and belt, the belt if you pass your hand under and feel that you stick your hand, and should be changed.
Feb 19, 2010 | Exercise & Fitness
I have a pro form cross walk advanced 525x when i jog on the treadmill the track will stop rotating mid stride
the treadmill should have tension adjusting screws. they'd be on the back of the treadmill where the belt wraps around the rear roller, they're inset and you'll need an allen wrench to adjust them. the screws adjust this rear roller. you'll want to tighten them to increase the tension. they also straighten the belt. if your belt is too fat to the right, you'll want to turn the adjustment screw on the right clockwise to tighten and this will bring the belt over to the left. and vica versa for the belt being too far to the left.
Feb 18, 2010 | Proform Crosswalk 500 Treadmill
How do I repair the seam of the walking belt? There is about a 5" wide seam on the walking belt and one end has come undone (about a 1/2 inch. It catches each revolution & I'm afraid that it is going...
Be extremely careful when trying to trim a belt. Understand that many hazards exist when performing these steps that can result in serious injury. If you have any question whether you can perform these steps or not, please call a professional and do NOT attempt this repair.
There are two methods that can be used to trim a walking belt when it has developed a tattered edge:
1) Remove the belt from the treadmill for trimming.
a) All walking belts are cut at some point during their life, whether in manufacturing or later during service, so this will not compromise the integrity of the belt as long as you cut a straight line and do not leave a rough edge.
b) Remove the walking belt from the treadmill, lay the belt flat and even on the ground, and measure and equal distance on each end of the belt and mark the belt for cutting on each end of the belt. Cut no more than necessary to restore a smooth edge.
c) Use a piece of flat steel or other metal object that is straight and long enough and connect the two markings on the belt with the metal object.
d) Using a new razor knife, box knife, or similar instrument, cut the belt along the steel object. If the knife has a new edge, you should cut through the belt in one or two passes of the knife.
e) Check the belt for a smooth edge and reinstall the belt.
2) Cut the belt while it is mounted on the treadmill. This method should only be considered by those who are familiar with treadmills and very good with tools. This can be a dangerous process.
a) Track or center the belt off center to the opposite side of the tattered edge (i.e.- if the belt is tattered on the right side, track the belt off centered to the left side by about 1/2 to 3/4").
b) Operate the treadmill at a very slow speed. Usually 1.0 or 1.5 MPH will be sufficient.
c) Using both hands, line a new razor knife up on the tattered side of the belt. Make sure to cut no more than necessary to make a smooth edge.
d) With the belt moving and using both hands, lift the knife up and contact the belt making sure to hold the knife steady and keeping your hands and clothing as free from the moving roller as possible. You will not damage the roller to the point where it will hurt the operation of the treadmill.
e) Do not lower the knife until you see the belt separate from the tattered edge. Once this happens, turn the treadmill off, unplug the treadmill, and cut the tattered strip off the treadmill.
f) Track or center the belt and operate normally.
Feb 13, 2010 | Proform 730 Folding Treadmill Model...
Exercise & Fitness Logo
788 people viewed this question
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
