I have magic chef chateau 8114p471-60, double oven for a long time we you shut the door the digital clock would go out, although everything worked , noe oven doesn't work and says F3
There are a lot of possible causes, but I'd look at the door switches first, and the wiring connectors to them. Make sure the contacts on all the switches are opening and closing.
I just had the top completely off of our Magic Chief, which I love and refuse to part with, to fix a problem with one of the burner switches. I believe if you pry up gently in the crack in front with a blade, i.e. small pry bar or screwdriver, being very careful to not chip the paint, the top will snap loose from the two prongs that hold it in place. Then if you disconnect the cluster of wires going to the burners, which is very easy to do, (they just plug together) and remove one screw holding the ground wire toward the back, you can lift off the whole top and get to all of the good stuff. I find the quality of our old Magic Chief Chateau to be of exceptional quality, much better than I see today and I'm pleased that our burner problem was just loose screws. Good luck.
Is the model number listed 251v-2CW that of the Oven or the part # of the element? That number is not showing up as either as a proper model #. Can you double check the Oven's Model # and list the Serial Number as well?
F1
1.
Watchdog on board 2. Touch membrane defective
To determine
which component is at fault, disconnect ribbon strip. If
NO fault code, replace membrane, otherwise replace board
F2
Oven too hot
Check oven
temperature sensor
F3 F4
Open or shorted
oven temperature sensor
Replace
F5
Hardware and
watchdog circuits disagree
Replace clock
assembly (also called the ERC)
F6
Missing AC
signal
Replace clock
F7
Function key
shorted
Replace touch
pad
F8
Analog/Digital
converter
Replace clock
F9
Door latch
Check door
lock circuit
F10
Function key
stuck
Replace touch
pad
F1
1.
To determine
F2
Oven too hot
Check oven
temperature sensor
F3 F4
Open or shorted
Replace
F5
Hardware and
Replace clock
F6
Missing AC
signal
Replace clock
F7
Function key
shorted
Replace touch
pad
F8
Analog/Digital
converter
Replace clock
F9
Door latch
Check door
lock circuit
F10
Function key
stuck
Replace touch
pad
