Question about HP Photosmart C4580 All-in-One InkJet Printer
My printer says there is a paper jam when there is no such paper jam. when i click ''ok'' on the printer, it begins to make noises repeatedly as if in a cycle and then goes back to saying ''paper jam.''
    Scholar:
  • 144 Answers
HI
I'm sending you a link which will help you with this concern,it has a good video demonstration for removing the Paper Jam
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01588752&cc=us&lc=en&dlc=en&product=3418707
Posted on Jul 17, 2009
Hp c5280 - when turned on loud clicking noise where cartridges are. it says paper jam but there is no paper jam in back of printer.
if u r sure that there is no paper jammed inside then probably u will have to reset the unit and even if that doent work u will have to take it to the service center...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00909241&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3204464
follow the ablove link... make sure u do all the steps from the beginning
thanks
agnel
Mar 17, 2011 | HP Photosmart C5280 InkJet Printer
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper Jam, paper feed issues
dear sir good day this printer have a common problem in the separation pad part and it need to simply replace ... so please take your printer to the tech company to replace it for you or buy it from it ((mention the printer model for the co.)) and download the service manual from the printer manf. site and do simply install the spare part and it'll work thank you
Jan 08, 2010 | HP PSC 1610 All-in-One Printer, Scanner,...
The printer says "paper Jam" but no paper is in it. When ever i click "ok" it makes a loud noise and says "please wait" but it doesnt do anything. What do i do?
Dont worry about that. Try to visit this website this website it will help you to solve that paper Jam kodak.com/go/stepbystep
Nov 19, 2009 | Kodak ESP 5 Printer
Repeat warning
Have you tried removing/re-inserting the ink cartridges??
May 16, 2009 | HP PSC 2355 All-In-One InkJet Printer
Paper jam when no paper has been anywhere near it, 1/2 INSTALLED
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 27, 2009 | HP Photosmart C5280 Printer
Panasonic UF-7000 Fax - paper jams and noise
Sorry to say you probably have a broken gear on the fuser assembly.
Very expensive to fix.
Mar 09, 2009 | Panasonic PanaFax UF-7000 All-In-One Laser...
2575 paper jam
You could try gently shaking it and see if anything falls out.
You should also try cleaning it, first maybe with some compressed air, you may have a dirty sensor or something
Another thing you should try is unplugging it and allowing it to reset.
Please let me know how the above work out and I can give you further options to try if none of them work.
Thank you for using Fixya and Have a Great Day!
Apr 18, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP Photosmart C4580 All-in-One InkJet Printer Logo
417 people viewed this question
Seeker5211
Seeker5211
