Question about GE GSS20IEP Side by Side Refrigerator
Don't know how to connect the water line to the unit there are two separate line for the water and the ice maker
  • GE Master
  • 5,568 Answers
The ice maker is intended to tolerate the same water pressure as the cooled water supply so you only need to 'tee' them together can be had at any hardware store) and you should also buy a sink-type valve to put in the line so it can be conveniently shut off if need be. The sink-type valve will have similar dimensions but you should check the inlet line size before buying your parts. Safest would be to cut a 1/4" length from one of the lines to take with you.
Posted on Jul 17, 2009
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: NO ICE - IC6
George, the ice maker will cycle about every 2.5 hours. Sometimes it takes a couple cycles to prime the lines. You can remove the white cover of the ice maker. On the module you will see two ports, one marked L and another marked V on the left side. Take a insulated jumper wire and jump these two terminals. You are now sending 120V to the valve. See if the water starts coming in. Also make sure the bailing arm is down. Catriver...post back.
Posted on Nov 05, 2006
SOURCE: HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Posted on Aug 19, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Cube and water sensor on control unit don?t work.
Do you have a Brand Name and Model Number?
Posted on Jun 22, 2009
imufo2
  • 3773 Answers
SOURCE: The ice maker is not making ice. The freezer
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 20, 2011
Testimonial: "These are all very good technicial solutions. I have done pretty much all that was suggested, except for pouring water into the ice maker. Thank you. "
No water coming from water line to refrigator
There is a water solenoid at the water inlet in the back of the refrigerator that is operated by the ice maker unit. It is separate from the water dispenser. Make sure the wires at the ice maker are fully seated and not pinched at the door hinge. If the wiring looks good, then the solenoid needs to be replaced.
Feb 20, 2016 | Kenmore Sears Refrigerator Replacement Ice...
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
LG LFX21976ST refrigerator. Started the day with a full reservoir of ice, was using it heavily to keep some workers hydrated. The last time I tried to get ice, none came. Per the label inside the doo
The ice maker's water supply line may be frozen solid. Do not worry... take out your frozen groceries and dairy products, and let your friends store them for two days while your completely defrost your refrigerator. If you don't want to wait, try to locate a schematic (parts diagram) for your fridge and take a panel access cover off to get access to the copper tube of the water supply line inside. (Warning: this can be terminal to your fridge so don't attempt this without the exact parts diagram for your make and model.) Ensure you are heating the water pipe and NOT the refrigerant line; i.e., freon, ammonia, etc... Unplug your fridge and heat up the (water supply) copper pipe with a high wattage blow dryer... if you were a pro, I would recommend a heat gun. DO NOT USE A HAND TORCH as the soldered joint connections may come loose and it will leak afterwards. (The demand you placed on the ice maker caused the compressor to run almost continually for the ice maker assembly causing the copper pipe water supply pipe to freeze... it will take time to thaw it out by just unplugging it. In the future, when you know you need volumes of ice... make a little at a time each day and store it inside a separate ice cube container.) You may also want to check the activation lever above the ice cube container (bin) to make sure it moves freely against the switch contact. If the switch contact is jammed, it won't work. Good Luck
Oct 02, 2012 | Refrigerators
Frig ice maker just quit. It is a side by side w/door dispenser. The H2O works. Anything that I can check before calling the repair man
Yes, Check the folllowing things in this order:
Make sure the plug where the ice maker plugs in inside the freezer isn't loose. Sometimes just unplugging and re-inserting the plug will fix it. If ok, read on...
You'll need a good flashlight. Open the freezer door. Remove the ice bucket. Shine the flashlight at the water inlet and chute to the ice maker and check for an ice clog. This is the point at which the water enters the ice maker. If you see an ice blockage, you can thaw it out with a hair dryer, but be careful not to get things too warm or you can warp plastic parts. If your unit has a water chute, remove it first and thaw it out separately.
Next, if the above isn't the cause, pull the machine away from the wall, follow the water line on the back of the unit down from where it enters the freezer compartment, and it should lead to the water fill valve. Remove the back cover or panel. Make sure you have water coming to the valve. You can loosen the fitting to the valve from the water supply slowly with a pan under it to catch any water that may come out. If water pressure is present, it could be the valve or on some units, an inlet screen to the valve may be clogged. If no water, then there's a problem with the supply somewhere, but this isn't as likely because you said the water dispenser works. You will need to turn off the water to the appliance before going any further. After the water is off, remove the inlet fitting and check again for water pressure. If ok, look at the inlet to the water valve and see if anything is clogging the valve. If so, clean it out, re-connect everything, and turn the water back on. Check for any leaks. Open the freezer compartment and cycle the ice cut off arm (move it up and down carefully). Wait several minutes to see if the ice maker fills with water. You should hear a click at the water fill valve. If it does work, discard the first round of ice cubes because you had the water line off and the ice could be contaminated.
If still no luck, you can check the water inlet valve with a test meter, but this requires familiarity with electrical apparatus. It's possible to power the water valve from a separate electrical source to test it, but only if you know how. This can be dangerous, so if you aren't comfortable doing this, it's best to call for repair. If the water valve checks out, then you may have a bad ice maker, especially if the unit is over 10 years old.
Feb 08, 2010 | Kenmore Refrigerators
Water line from house supply sprung a leak just before going into the ice maker control unit in the lower right cornor of the frig. After replacint the water line the water did not flow into the control...
What once was a leak is now no flow and no response when trying to turn on ice maker? Is the valve where the ice maker line taps into turned back on? If it's back on, first turn it off, take loose water line as close to ice maker as possible, then have someone else turn valve at tap slightly on while you watch for water flow. If no flow, start back-tracing your connections until you find the blockage. Most water connections of this type have a in-line filter. Is it clogged? If you have water pressure as close to the ice maker as you can test, next you may need to troubleshoot the ice maker it's self. Let me know?
Jan 02, 2010 | KitchenAid Superba Architect KSCS25INSS...
Not getting water to ice maker but have water at door.water is turned on, just moved today ?
bad water valve or frozen line,there are separate water lines from separate valves but you buy the valves as one unit.look at tube that fills the ice maker,if you see ice melt it out with a hair dryer or stick a screw driver up the tube if you feel it hitting something it's probably ice,melt it out
Oct 30, 2009 | Kenmore Refrigerators
Water line hooked up to unit for icemaker but water will not travel up plastic line to the icemaker
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 12, 2009 | Maytag MTB1895AE Top Freezer Refrigerator
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Sep 03, 2009 | Freezers
yes, there is 2 lines, one for the water and the other for the ice. you can take the back lower panel behind the frige and take a look at the water line coming from the house where it connects to the frige, you can disconet the line that goes to the freezer, and put the line inside of a container of about 1 litter, and waite for about 30 minutes it at to have some water inside just enough to fill the ice maker. if you donot get any water, replace that valve.
Dec 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE GSS20IEP Side by Side Refrigerator Logo
113 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
