Question about Amana Dryers
Ignitor heats up,gas pressure at valve. When gas valve opens, pressure drops with no igition
  • nascarste1 Jul 17, 2009
    I just want to make sure this problem has nothing to do with the heat sensor or the resistor ring before buying valve. I tried ohming these out but readings made no sense to me.
    Top Expert:
  • Amana Master
  • 76,630 Answers
Assuming you have good gas line pressure the only thing this can be is a defective gas valve.
Posted on Jul 17, 2009
  • yadayada
    yadayada Jul 17, 2009
    the temp sensor idea it doesn't make sense, if the temp sensor was defective it seems to me the gas would flow but then shut off early.
The Hi and Lo gas valve coils do they work in tandem ? Does the Lo stays on all the time ? Ruy ...
Their is 2 coil hosing but one of them has 3 wires and 2 coils inside it. The ignitor does 2 jobs, it lights the fire and acts as a thermocouple through the holding coil. If the flame does not ignite after the sensor detects the heat from it and shuts down then once the ignitor cools down the gas valve is shut down even if power is going to the gas valve. When the temp drops below 105f in the drum the control closes contacts inside allowing power to be supplied to the gas assembly. The ignitor and flame sensor along with the booster holding and secondary coils are all energized at once but the solenoids won't open the valve because the ignitor is hogging the power. The power supplied to it runs through the flame sensor. When the temp inside the sensor reaches a point the bi-metal inside tripped the power to the ignitor and the power gets diverted over to the secondary coil. Thr flame stays on till the temp inside the drum reaches 160f at which time the control thermostat opens circuit to the gas assembly and power is shut down. The drum continues to tumble and when the temp drops once agin below 105 the process is repeated and another blast of heat is shot into the dryer. So what goes wrong? Faulty flame sensor sticking/open, cracked ignitor, old coils that work intermittently or not at all when hot but work again when cooled.themobilian_2866.jpgthemobilian_2865.jpg themobilian_2868.jpgMore here.
Aug 21, 2011 | Whirlpool GGW9878P Gas Dryer
Not heating completly
It is probably only the ignitor is just cycling. First remove the bottum plate and tap on the gas valve as it sometimes rarely it will get stuck. However it is most likely a faulty timer as the gas valve uses the EMF or back voltage pressure to open the gas valve. If you get the ignitor and the solenoid kit for the gas valves you can't miss it. As stated it is most likely the ignitor so that is the starting point. Good luck!
Mark,
Feb 07, 2011 | Kenmore 77632 Gas Dryer
Dryer is not heating up it runs does the ignitor heat up before gas valve opens because the ignitor never heats up
On my gas appliances, either there is a pilot light or the ignitor sparks (like a car spark plug) or glows after the gas valve opens. The ignitor does not heat up.
I've had some gas appliances that have had the valve stick. (On an oven, we tested this by tapping on the valve when the unit should have called for gas. This confirmed that the valve was bad and not the thermostat.)
I hope this helps.
Dec 07, 2010 | Amana NDG7800AW Gas Dryer
Not heating during drying. everything else works
There are 3 things to turns on the heat. The ignitor, the thermal sensor, The gas valve. The ignitor has to glow first when you start. if it doesn't then it has a problem right there. After the ignitor comes on, and the thermal sensor has to produce some voltage so the gas valve can open to fire a flame then the heat will start. If the thermal sensor is bad, valve can't open then the ignitor will shut down, hence there is no heat.Taking the back panel off and try look to see the ignitor when you start so you can diagnose it correctly. Good luck
Apr 22, 2010 | LG DLG5932W Gas Dryer
Goodman gps100-4 heater, tied to heat pump intermittent gas valve operation. all safeties check ok.
If you have 24v to gas valve and a good ground to unit, check gas pressure with a manometer to ensure your input gas supply is correct..11-13" w.c. for LP and 5-10" w.c. for natural. If out of that range, valve may not open. You have to ensure you have 24v to valve after ignitor comes on..about 5-10 seconds after ignitor starts glowing. I would check from pos side of valve to chassis ground. If you do and your input pressure is good, you have a bad valve. Monitor the voltage to the valve to make sure it does not lose partial voltage during the 3-4 seconds it is energized before the flame sensor stops the sequence. And keep the manometer on the input side while the unit is firing so you can see if the pressure drops when the gas valve opens. If it does, your regulator outside is not working right.
If those look ok, see if you get output pressure when it does not fire. If you do...3.5" for nat, 10" for LP, the ignitor may not be getting quite hot enough every time.
Hope that helps a little
Jan 06, 2010 | Goodman PHKJ048-1 Air Conditioner
Gas burner will not light. it has a s86c control intermittentpilot 100% shutoff . I HAVE 24 VOLTS AT THE CONTROL COMMING IN BUT NO VOLTAGE TO THE GAS VALVE . NO SPARK AT IGNITOR. PLEASE TELL ME THE...
Therm calls for heat, enducer fan turns on, pressure switches closes, ignitor sparks, gas valve opens. If ignitor does not spark, it will go to try a few times then lockout. Do you have a led code on your control board, if so what is it blinking? Could be ignitor bad only..
Dec 04, 2008 | Heating & Cooling
Crosley (Maytag) CG3478VVD Gas oven not heating properly
It's possible but a failing (ignitor) can cause this too. It might be barely passing enough current to hold the valve fully open. Check the rating on the valve and then the current draw of the ignitor. Or sub in another ignitor. Also low gas pressure can cause it too. Have your utility co check for this
Dec 28, 2007 | Ovens
Amana oven gas leak issue
staunch has no idea what he is talking about. It has nothing to do with the igniter, or it would fire up at all. Since you are saying that your oven does ignite and heat up, it is the internal gas valve that is the problem.
The way all recent (20 year at least) are designed, the gas valve internally can not open unless the igniter is working, for obvious reasons ... boom! The igniter circuit allows the gas valve to open, once it detects that the igniter is ready to "ignite" a gas flow. BUT, the valve can be bad in the AMOUNT of gas being delivered. Your's is allowing too much gas, more than can be burned, hence the smell.
DON'T use the oven until you have a qualitifed tech come out and replace the valve. It is very dangerous for you to do it yourself.
Nov 22, 2007 | Kitchen Ranges
Dryers Logo
23 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
