Question about Ruud UBHC Air Conditioner
I have a 17J20 Ruud electric furnace that is only drawing 39 amps instead of 82, only producing half the heat. What could the problem be?
  • 614 Answers
All sequencers not wired in or bad sequencers. RUSS
Posted on Jul 18, 2009
Ruud Achiever 90 - too much heat. My gas furnace works with propane. When it kicks in, it produces too much heat so that the temperature in some very well ventilated rooms gets to 80F.
The heat is controlled by the room thermostat so may be that is not working . It may have a variable fan speed which could help you . but you would have to check that out with the makers .
Dec 14, 2017 | Ruud Heating & Cooling
Ruud furnace troubleshooting
check that elements are intact and getting voltage
Nov 14, 2013 | Heating & Cooling
Ruud gas furnace burners won't ignite
Remove the stat cover and jump out the red and white wires. If the furnace still doesn't come on, it is your t-stat. Replace it.
Mar 12, 2017 | Heating & Cooling
Rudd silhouette ii blower
Send direct power to the blower by bypassing relay . See if motor runs
Jul 19, 2017 | Ruud UBHC Air Conditioner
Furnace is a Rudd UGEB model. Burners ignite and but the blower (squirrel cage) doesn't start. After a couple minutes they turn off and the blower starts and runs for less than a minute and shuts off....
Sounds like the fan limit was not replaced correctly. You can try switching the blower to the On position (instead of Auto), if the furnace runs properly with the blower on that would be the most likely culprit.
Sep 24, 2011 | Ruud UBHC Air Conditioner
I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
Jul 01, 2011 | Ruud UAMB Air Conditioner
Drawing current but not producing any heat.
I am assuming this is an electric wall mount heater, if the unit is drawing current then it should relate to heat as 3.41 btu is = 1 watt.
take the voltage reading and the amp draw and mutiply them to determine the wattage eg; 240 volts x 20.8 amps = 5000 watts = 17,050 btu. if the unit is fan assited and you are drawing 1 to 2 amps this would indicate the fan is runnning without the heat element being energized hope this helps
Nov 04, 2009 | Fahrenheat (FFH1614) Wall Mounted Panel...
Ruud heat pump
Did you just install this heat pump? If so it sounds like you replace a regular a/c with a heat pump, which will require more wires for the reversing valve. First check to make sure you have 24v going to the condenser. Make sure you have a heat pump t-stat. You should have a orange t-stat wire for your reversing valve. At the t-stat you will have terminals R, Y, G, O, X or C or B, W1, and W2. R is half of your 24v circuit and is a red wire, Y is for cooling mode, G is the Fan green wire, O is for the reversing valve, orange wire, X or C or B is the other half of control circuit blue wire, W1 and W2 is the heat strips in the furnace tan and black wires. These are standard color code but remember electricity does not know colors and an installer may have used different colors. If all of this is correct possibly bad contactor.
Oct 30, 2008 | Ruud UAMB Air Conditioner
Ruud achiever heat pump
If back-up heat comes on when a/c is turned on and then the back up heat turns off shortly after the a/c turns off, then the low voltage wiring is NOT correct. Your "R" terminal is basically your "hot" and your "C" terminal is basically your "neutral" to simplify explanation. The Furnace supplies the "R" power to the thermostat and then depending on what wire the thermostat sends the power back on determines what the system does. The thermostat terminals are as follows "G" is fan, "W" or "aux" is elect heat, "Y" tells the outdoor unit to run, "O" or "B" tells the outdoor unit whether it is heating or cooling, and "E" is emergency heat. "G" should connect from the t-stat directly to the furnace and go no further. "W" or "aux" AND "E" should both connect to your "W" or "W1" terminal in the furnace, there should also be a "W" connection to the heat pump ( this allows the H/P to turn on the elect heat when the unit defrosts) "Y" and "O" or "B" may or may not connect to a terminal in the furnace, usually they just pass through the furnace from the t-stat to the H/P and get wire nutted in the furnace. Now, here is the key. As I mentioned previously "O" or "B", a system will only use one or the other. The entire industry (except for Rheem and Ruud) uses the "O" terminial which has 24v on it when you are cooling and no power when you are heating. Rheem and Ruud use the "B" terminal which is just backwards, 24v in heating and no power in cooling. this could also be your problem if the t-stat thinks it is telling the H/P to cool but the H/P is actuall interpreting the signal to heat. Check your amp draw on the furnace, if you have anything drawing 15 amps+ then it is most likely the actual elect heat running, if not then check the "B" terminal. Most universal t-stats come set from the factory to use the "O" terminal which is more common. Usually this can be changed in the installer setup menu on the stat or sometimes the stat will have separate "O" and "B" terminals
Jun 15, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
64 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
