Question about Frigidaire FRT18B4A Top Freezer Refrigerator
Water =underneath= the refrigerator
I think the drain is working okay, I just think the drain pan is overflowing, but I can't tell because there doesn't seem to be a way to get at it. I just see water underneath (not at the inside bottom). Manual no help and makes little mention of it. Sears 106.7425 top freezer, bottom fridge. Humid Hawaii climate probably is partly to blame, but why don't they make the pan servicable?!
  • Frigidaire Master
  • 8,220 Answers
Check you door gaskets for gaps or cracks that would allow air to get in the frig. Look for a bad water valve or ice maker head. If your ice maker is faulty it will instead of filling for 7 seconds it will fill the ice mold for 30 seconds. Put the arm up to stop ice production and wait awhile. Then lower the arm and observe the harvest cycle. The water valve should be energized for 7.5 seconds very near the end of harvest cycle. Just a GUESS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 17, 2009
I need to stop water from getting on the floor of the freezer?
If your refrigerator is frost-free, water may not be draining into the evaporator pan underneath. The drain tube may be clogged.
Dec 18, 2014 | Refrigerators
Whirlpool refrigerator drain pan overflow
Check the freezer and fridge settings, are they in the middle range? If the machine is working too hard, it will ice up, making more defrost water.
Also, check all the way around both door gaskets, they should hold a dollar everywhere. If there is a gap, the door can be straightened fairly easily, just a little twist.....
Nov 29, 2013 | Refrigerators
My evap pan keeps overflowing
The pan in the inside of the unit or the one underneath for collecting and evaporating the water?
If it's the one inside take the front bottom panel off and blow out the drain line leading down there. If its the pan underneath and it cant keep up with the water flow check to be sure it has some white cotton looking panels in the pan. They are an accessory called a wicking kit designed to absorb the water and as the air blows over them they help evaporate the water. If those are present and in good shape but its overflowing there you may need to get an electric condensate pan.
Aug 28, 2013 | True GDM-33-SSL-54 Refrigerator
Water is pooling and overflowing in drain pan underneath refrigerator portion of side by side unit. Had left door open one eve and also lost power a few times this week, contributing to problem. How do i...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 04, 2011 | Jenn-Air JCD2389G Side by Side...
Drain Pan fills and overflows. Cannot get to drain pan to empty. Why the water and how do I get to the drain pan ? Also the refrigirator door maes a loud sound when It's opened and closed. It seems to...
The water is normal....however the evap motor and fan should be drying the water before it overflows. THe evap fan motor may need replaced. You will have to pull the unit from the wall and take the back panel off or tilt the unit back towards the wall and go in from the underneath side. As far as the door goes....you might need to tighten or replace one of the hinges.
Sep 01, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Have side by side 10 years leaking water on floor in front of refrigerator there is no water connected to refrigerator, cant find an overflow pan under neath...
clogged drain causing the water that cant reach the drain pan underneath to leak on the floor. Unplug fridge and open doors for 24 to melt ice likely clogging up drain. If that doesnt fix, you'll need to call refrigerator repair service
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
Refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Sep 11, 2008 | Refrigerators
Drain Pan overflowing
Refrigerators use different methods to eliminate the water, but they all use evaporation of some sort.This works,as most of the water in the drain pan comes from melted ice on the evaporator coil during the defrost cycle, and this is not very much. It sounds like you have excessive water in the pan. You stated the freezer/fredge is working properly. The condenser fan is running, I assume. Cleaning the dust off the coil will help the air flow. Most residential units do not have heating element in the drain pan. Your problem sounds like you are getting too much water in the pan. Have you noticed excessive ice in the freezer? Are the door gaskets in good shape. Does the unit have water and ice in the door? If so, where does the drain to, and has there been high usage of this?
Nov 11, 2007 | Jenn-Air JCB2388G Side by Side...
Frigidaire FRT18B4A Top Freezer Refrigerator Logo
181 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
