2010 Jeep Liberty Logo
a
armando osorio Posted on Jun 17, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do a 2010 Jeep Liberty Have a Automatic transmission dip stick?
Need to know if my vehicle has a dip stick to check the automatic transmission fluid level?
  • Shawn Jun 17, 2016
    Alot of those newer vehicles have maintenance free transmisions so they dont have dip sticks.
_-__-___-_
Level 3:
  • Jeep Master 20,706 Answers
  • Posted on Jun 17, 2016
_-__-___-_
Jeep Master
Level 3:
Answers
20706
Questions
Helped
6801724
Points
57965
In the usa? KK jeep?
did you read the operators guide first. it does not mention that.
why,
its gone.
answered now 100s of times.
the FSM (KK) Factory service manual) is where this IS NOW.
this is to keep people from damaging the box.
using wrong fluid
or overfilling it
or not reading how to do it correctly. (its not done like engine dip)
2008 was the change, 2007 both boxs had DIP.stick.
Shawn
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 8 Answers
Shawn
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
8
Questions
13
Helped
2084
Points
27
Alot of the newer vehicles have maintenance free transmisions so they dont have dip sticks. And if it is maintenance free it will tell you under the hood.
5 Related Answers
Anonymous
  • 716 Answers
  • Posted on Jan 06, 2009
SOURCE: I have a 2007 Jeep liberty
Check Again It May Be Like A Dark Red Brown Color Best Advice Is To Look Toward The Transmission From Engine View.
c17hydro
Greg Bernett
  • 2993 Answers
  • Posted on Mar 31, 2009
SOURCE: Identifying 2003 Jeep Liberty Automatic Transmission
What is your VIN number?
Anonymous
  • 4669 Answers
  • Posted on May 15, 2009
SOURCE: My 1996 jeep grand cherokee wont shift into 3rd
Does Reverse work?
Anonymous
  • 11896 Answers
  • Posted on Sep 28, 2009
SOURCE: how do I check the level of fluid on a
Go underneath and look at tranny, There will be an upper filler plug and a lower drain plug. You can get top and hose for your gear oil / tranny fluid and fill. The level of the fluid should be exactly at bottom of hole
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 13, 2009
SOURCE: what kind of transmission fluid does a 2001 jeep wrangler need?
Chrysler ATF+4
Testimonial: "quick and clear"
2answers
How do I check the trans fluid in my 08 Jeep Liberty.It didn’t come with a dipstick
With automatic tranny, you should have the dipstick tube and it is caped. Note the dipstick in the picture. 9336 . Did you read your owners manual? Make sure the dipstick will work with your vehicle. You don't leave the dip stick in. Hopefully the dip stick comes with instructions. Your owners manual says to check automatic tranny fluid, engine running. Hope info helps.
Where do you add the transmission fluid for a 2010 chrysler town & country on the engine is it where it says dealer only
The automatic transmission dip stick and filler tube have been removed from many later model auto transmissions now so you cannot check fluid levels yourself or add fluid easily to these units.
I assume you have the V6 engine and if you check the engine bay you will find no transmission dip stick and filler tube there. In these cases you have to add fluid by pumping fluid in after removing a filler plug on the case of the transmission from under the vehicle and it needs to be perfectly level when this is done.. There is a specific procedure for this which varies from unit to unit because you need to ensure the transmission is not over filled.
Unless you know what you are doing and use the correct filling procedure this is not a do it yourself task and it is best done with the car perfectly level up on a workshop lift/hoist.
Where do you check the transmission level on a 1995 Polaris 425 Magnum. How do you add fluid?
on any vehicle with an automatic transmission, there are two dip sticks. One to measure oil level, and the other transmission fluid level( typically labled 'check with engine running in park'). To add transmission fluid requires a funnel to introduce fluid via the dip-stick tube.
If you have a manual transmission, then you don't need transmission fluid, you need gear oil, which can be measured at the transmission and added at the same port.
Why does the transmission dip stick keep coming out on my 2006 Jeep Liberty Diesel 4x4
it pops back>? that it? (coming out?) leaking fluid? that?
inserted wrong, ?
some need to be inserted correctly or they jam up inside.
true for many sticks, no round.
flat blade sticks,
or damaged dip tube.
What type transmission fluid I need for my 2004 jeep liberty
OE Multi-Vehicle Synthetic Automatic Transmission Fluid. Or refer to You Tube.
1helpful
How to Check Automatic Transmission Fluid?
run the vehicle until the engine temp guage is in the yellow .
with the engine running, open the hood and pull the transmission dip stick.
read the stick and replace fluid that has been lost , or whatever...So long as the engine is warm (hot) the reading should be accurate on the dipstick.
3answers
Where do you fill the automatic transmission?
If you have a tranny dipstick, then you would need a long tranny type funnel and fill there.
If you do not have a dip stick, then you would have to raise the vehicle, and look at the tranny. There will be a higher and a lower plug on it. Remove the higher plug and stick your finger in the hole. If you feel fluid, then it is full.
1helpful
2answers
How can i put transmission fluid into my car,how much do i put in
Check the Level of the transmission fluid by pulling the Transmission dip stick. The colour of the dip stick is most likely red in colour and you need to check it with the car's engine running and hot. Pull the dip stick out clean it off and check it again. always check the second reading.
To fill the transmission, you need to fill it through the Transmission dip stick tube. Yes your going to need a thin funnel and good luck. Do not over fill the transmission. over filling will cause damage to the transmission.
Best thing is, if you have not done a transmission oil and filter change. Have it done at a Transmission shop and you'll know that the transmission level is fine and have them show you have to check and fill the Transmission. As time goes by and mileage get's high, the fluid will get contaminated and the filter plugged up which would in turn cause a transmission failure.
Good luck and hope this helps. Oh and the type of transmission fluid should be in your manuel or stamped on the dip stick.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
