Question about D-Link xStack DWL-2230AP (DWL2230AP) 802.11b/g Wireless Access Point
Hi there, I have D-Link xStack DWL-2230AP 2230 AP and I can't get connected to internet,because I don't know the IP Address of this model. please help, john
    Problem Solver:
  • 12 Answers
The default IP address is 192.168.0.1 or 192.168.100.1
Posted on Jul 17, 2009
I am having Wirless A/G Outdoor AP/Bridge "DWL-7700AP" how to configur with Direct ADSL line 192.168.0.50 d-Link IP
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
If still not able to access it then you need to reset it for that press RESET button for 10 seconds it is in back side of router.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
WAN settings are your internet service provider settings if you want to know wireless settings then click on wireless then you can find your wireless settings .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 19, 2010 | D-Link DWL-7700AP AirPremier Wireless AG...
TALKING ABOUT THE ACCESSING THE IP ADDRESS ON THE DWL-2000A,I DON'T THINK I UNDERSTAND THE SOLUTION TO THE CONNECTION BECOS THERE IS ONLY ONE LAN PORT ON THE AP WHICH ONE CAN CONNECT TO THE MODEM. SO IF...
To connect the AP directly to your PC you sould need a "crossed" LAN cable.
On you PC you need to set a IP Address of the same subnet of DWL-2000AP (defaul IP is 192.168.0.50) like 192.168.0.xxx
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and select "Internet Protocol (TCP/IP)", click properties, now set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
Confim clicking OK OK OK...
Now you can access you devices tipyng http://192.168.0.50 on your prefered browser. Default login is "admin" as username and empty password.
Let me upate.
Sep 13, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Cant get accesss to the configuration window
In order to get to the AP, and assuming you just plugged it in, you need to put everything in the 192.168.0.x domain. The AP defaults to 192.168.0.50, so you need to make sure that the router gives out IP addresses that does not include 0.50, or change the IP address of the AP. Likewise, the computer you are trying to log into the AP needs to start in the 192.168.0.x domain, with x being anything but the gateway address (normally 1), or 50.
My guess is you have a router built into the modem and it is giving out different addresses. You can set your network address by hand to be 192.168.0.pick a number like 5 and plug into the ethernet port of the AP (may need a crossover) to get to it.
Post back and let us know what you found.
Carl
May 15, 2009 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
Installation problem
problem in the firewall ,ip address, proxy server, and antivirus if there all then change it disable the firewall, proxy server, any antivirus and check the ip address is give right or wrong
Feb 15, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
How to access Dlink Set up page ?
You must be in the same subnet as your device in order to configure it. If you are in the 192.168.1.0 subnet, change your IP address on your computer to the 192.168.0.0 subnet. Assign yourself a static in that subnet with the last octet between 1 and 254, but not 50. I use 192.168.0.250, but any unused IP address in that subnet will do. Once you are in the same subnet, you should be able to reach your AP. If you still can't get to the http interface, then go to plan B: Your access point came with a CD: D-Link AirPlus Xtreme G AP Manager that provides an alternate client interface. You can setup security and change the password, and SSID using the client interface software if your http connection does not do it for you. Once you change your IP to the 192.168.1.0 subnet (which I assume you intend as it sounds like that is your LAN subnet), give the AP the gateway address of your router's IP address, and change your IP address back to whatever it was on your computer.
Nov 29, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Please help! d-link airplus xg dwl 2100AP
Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
IP: 192.168.0.66
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work.
Hope this Helps
Tech
CCNA, CCSP, MCSA
Mar 23, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
IP: 192.168.0.66
Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
Hope this Helps
Admin
CCNA, CCSP, MCSA
Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link xStack  DWL-2230AP (DWL2230AP) 802.11b/g Wireless Access Point Logo
114 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
