I have an iphone 3g 16gb white 3.0 just upgraded it from 2.2.1. my iphone freezes everytime i startup it hangs at the apple logo and even if it leaves that stage after some few mins it hangs . i have done countless restore. but it doesent work. please i need help urgently. thanks
how do i do that? cos i dont have anything on my file. i just restored and it keeps freezing. before and after startup.thankshow do i do that? cos i dont have anything on my file. i just restored and it keeps freezing. before and after startup.thanks
You can't post conmments that contain an email address.
If yopu have too much files on the memory pls delete some,if it persist just flash in new memory and the hanging will be detected and it will be corrected.
If iPhone won't turn on, or the display freezes or doesn't respond
Press and hold the Home button for at least ten seconds, until the application you were using quits.
If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This: 1. Remove Sim Card 2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears 3. Replace Sim Card 4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this: 1.) Shut down the iPhone 3G. 2.) Start up iTunes 3.) Hold down HOME button on the iPhone 3G 4.) While keeping the HOME button depressed, plug in the Sync cable 5.) A message will pop up to ask if you want to reset. 6.) Just click YES and the reset process should start.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it. Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears. If iPhone won't turn on, or the display freezes or doesn't respond
Press and hold the Home button for at least six seconds, until the application you were using quits.
If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets: Try This: 1. Remove Sim Card 2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears 3. Replace Sim Card 4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Try a reset. Hold down the power key at the same time as the round home key until phone powers down. Release buttons only when you see the apple logo, then wait a min or two for phone to re-boot. You will not lose any data on the phone.
If this does not work, try an actual system reset. Sync iPhone to computer to back up essential data ie contacts apps etc, then go to settings general and reset. Reset all settings as a last resort. This will give you a fresh start and should sort out the majority of any bugs the phone has. A resync with you computer will restore apps etc.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it. Reset To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears. If iPhone won't turn on, or the display freezes or doesn't respond
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.try this
