Sewing Machines Logo
W
Wendy Elizabeth Collinson Posted on Jun 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my machine make a terrible screaming noise
I've undone the side of the machine can see wheel belts and fly wheel clearly. When sewing the belts appear to grip well. It sews fine but terrible screaming noise. Can I undo the fly wheel.if so how?
Bill Boyd
Level 3:
Top Expert:
  • Sewing Machines Master 53,816 Answers
  • Posted on Jun 16, 2016
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11949764
Points
172802
Try oiling parts
remove any thread around the bobbin carrier shaft
take it in for a service
  • Wendy Elizabeth Collinson
    Thanks a great help. Oiled belts and now purring along instead of screaming at me!!!
R.A. Ellis
Level 3:
  • Sewing Machines Master 12,731 Answers
R.A. Ellis
Level 3:
Answers
12731
Questions
Helped
2619177
Points
59176
Really difficult to help when no info is provided for the machine brand/model. If it's mechanical, probably needs a good cleaning and oiling.
My Bernina 1300 MDC serger stopped sewing. The light comes on and the machine makes the start up noise but, when I press the foot pedal, nothing happens.The foot works with other machines.
check to see if any thread is jammed inside the right turning side wheel in the core area at times there can be thread that flies in there and may stop the main belt turning.
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
I need a schematic of the interior of my machine so I can repair it. Motor turns on, fly wheel and bobbin mechanism works but needle and bobbin area don't.
Service manuals for sewing machines are available. Do an internet search. If the needle goes up and down when you manually turn the hand wheel you may simply have a belt problem (broken or off the pulley). If the needle doesn't move when the hand wheel turns, there's a major problem in the mechanism.
1helpful
KENMORE 15612 MAKES SCREAMING SOUND WHEN RUN.
could possibly be that your wheel belt it to tight. Possibly you need to oil the stitching arm and other areas their should be small holes on sewing base and one on top beside the where the sewing arm is located
1helpful
2answers
Pfaff 139, need to replace motor to fly wheel round belt
There are plenty of sewing machine belt suppliers on ebay. A 41/2" diameter universal rubber belt should fit your machine
2helpful
Makes one stitch then abrupt stop with threads bunching up from bottom
Have you taken the bobbin out and made sure there is nothing caught in the bobbin race area. Maybe even unscrew the plate and take the whole bobbin race assembly apart and clean well. Once that is done put back together then re thread machine. Next I would start by hand turning the machine and doing some stitches slowly with the fly wheel make sure to to forwards only never turn the fly wheel back wards. If everything seems clear give it some power slowly and see how it goes.
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
2helpful
My ELNA 3005 machine is making graunching noises
Open your side cover. normally a screw on top and two on the bottom and maybe one on the side.
After removing the cover you will see one or two tensioner plastic black pullies.(they keep your motor belt and timing belt tight. They need a little bit of machine oil.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
