Question about Electrical Supplies
Location of circuit breaker 1985 Holiday Rambler
The AC stopped working today. I'm connected to power and I know the RV is still getting power, everything else is working, I just can't find the circuit breaker to figure out if it has been thrown. It's got the bathroom in the rear of the RV with the kitchen and a refrigerator just to the rear of the door.
thanks for any help
muttandjeff
  • 359 Answers
SOURCE: Air handler circuit breaker
WITHOUT ANYTHING TO LOOK AT I WOULD SAY HE CONNECTED HALF THE LOAD TO ONE OF THE PHASE WIRES AND THE OTHER TO THE OTHER PHASE WIRES , PHASE WIRES MEANING 120/240 SINGLE PHASE , SO IF THAT IS THE CASE TAKE THE WIRES HE HAS BUNDLED TO ONE PHASE OR ONE TERMINAL ON THE BREAKER AND THE OTHER TO THE OTHER TERMINAL OF THE BREAKER IN SOME CASES IT IS NECESSARY TO CONNECT THE WIRES WITH CONNECTOR, APPROVED TYPE AND THEN TO THE BREAKER TERMINAL ,THIS JUMPER SHOULD BE RATED THE RATEDING OF THE BREAKER YOU ARE INSTALLING ,GOOD LUCK
Posted on Nov 23, 2008
muttandjeff
  • 359 Answers
SOURCE: blown breaker
any moisture is a problem gfci,s trip @ 25 milli amp to ground this is very little get rid of all moisture you can and spray outdoor recepts with some contact cleaner this is available @ good hardware stores and electrical supp houses and will displace all residual moisture
Posted on Dec 31, 2008
  • 56 Answers
SOURCE: Replacement 15A circuit breaker does not work
If the light is a flouresent light more than likely the ballast is bad. Very simple to replace but make sure power is of..Very common problem.
Posted on Feb 16, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Refrigerator is getting no power
Check the relay and the compressor with a volt meter. Make sure that you are getting proper voltage. 110 - 120 volts at both the relay and the compressor. If nothing happens or everytime you try to test and the circuit keeps popping first check for bad wiring make sure nothing has come loose. If all the wiring checks out including the ground then the only thing that will pop a circuitbreaker is a bad compressor meaning it is drawing to many amp and you will either need to have a company replace the compressor for around 600 dollars or get a new unit
Posted on Feb 21, 2009
  • 163 Answers
SOURCE: help with fuel pump location 1982 holiday rambler.
It is in the tank. You need to drop tank and test voltage of wires going to pump to see if it is in fact the pump. Clean the tank if you replace pump. Look at the pump on Autozone.com
Posted on May 09, 2009
We have a 2001 presidential 5th wheel it is hooked up and plugged and everything works but the lights. Is there a separate switch to turn these on?
There is probably a breaker box in the bedroom closet behind a panel. Look elsewhere if not there and check the breakers when you find it. You may have a short circuit somewhere and the breaker opened. Or maybe even a failed breaker. Check for voltage at the breaker itself. Don't assume the breaker is getting power.
Feb 03, 2017 | Holiday Rambler 2010 Presidential 36RET
How do I locate the ac to dc converter on 1993 Holiday Rambler trailer
Usually right behind the fuse/ circuit breaker box.
Nov 11, 2016 | AC Cars & Trucks
Gas 1999 Holiday Rambler Endeavor. How do I remove the dog house?
1999 Holiday Rambler Endeavor 36 WGS Class A Motor ...
? 11:40
https://www.youtube.com/watch?v=7nsTuFfPZLE
Jan 17, 2014 - Uploaded by Parkwayrvcenter
Can you find Holiday Rambler Quality with a Slide Out and Low Miles for ... Normally that is impossible but Parkway RV Center has done it again ... ... Remove all; Disconnect ... 1999 Holiday Rambler Endeavor 36 WGS Class A Motor Home with .... 1997Holiday Rambler Vacationer class A gas motorhome ...Missing: house
Jan 07, 2016 | RVs
When you turn on the rear ac it sounds like it humms and then trips the breaker. Any ideas? Thanks, John
it could be the capacitor gone bad. without it the compressor can draw lock rotor amps.
Aug 02, 2014 | Coleman Dometic Duotherm Rv Air...
How do I locate the charging system wires at the converter ?
Should have the basic schematic in your owner's manual. If not, contact the mfg and see if you can download one or have it mailed.
No luck? Google it. If persistent enough, you can find one.
Jul 30, 2014 | Holiday Rambler 2010 Mintaro 26RKS
DO YOU KNOW WHERE I CAN GET THE SCHEMATICS FOR A 1994 HOLIDAY RAMBLER RV?
Most RV manufacturers do not publish schematics. It is up to the technician to trace the system and locate the point of failure.
Jun 03, 2014 | RVs
Need operators manual for 1978 Holiday Rambler motorhome. Where do I get one.
We do not have any access to Any motor home manuals.
Jun 05, 2012 | Cars & Trucks
Jensen back up camera moisture in lens
I would try a blow dryer on low to medium heat. Have someone watch the monitor with the engine off and the ignition on so if the view improves you can stop without over heating the camera behind the lens.
Jan 29, 2012 | AC 2 Cars & Trucks
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
Front A/C blowing hot air.
Do you have thermostat in proper zone mode?
If still having trouble, try calling customer service/tech assistance number in manual for Monaco or Holiday Rambler. If you don't have number let me know, I'll do some digging & see if I still have it. Or, get back to me with thermostat model & rooftop AC models.
Jul 07, 2009 | Heating & Cooling
Electrical Supplies Logo
154 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
