Question about Panasonic CW-C200NU Air Conditioner
Does not turn on
I tried to use this unit today and unfortunately, it will not turn on. I have checked both the power cord and the circuit breaker an d they seem fine. The manual states that there is an internal fuse, but they do not tell it's location and I don not see it. If anyone out there who can offer some help, I would greatly appreciate it.
Hot in NY
  • sbsrossi Jul 17, 2009
    Thanks for your quick response. Unfortunately this is an old school dial model. Got any ideas?? NY
    I didn't rank you poorly. They asked if your answer could solve my problem, I said no but that it was the right response to the problem. Thanks again
  • Panasonic Master
  • 8,220 Answers
If it is a touch pad operated ac then the fuse is sammiched in the middle between the touchpad and the board. Pretty slick ain't it? .3 amp is the size i beleive but don't hold me to dat.
Posted on Jul 17, 2009
  • Dan Webster
    Dan Webster Jul 17, 2009
    Why you done ranked me already as a 2? I would take a look at the capacitor and see if it is leaking or swolen or open . I would check the compressor for a burned wire. if common is burned on top then nothing will work on some models. their is no fuse.I would take a look at the switch as well Look on my website for all of these links I have made several pages that will help you.Sheesh a 2 dude? LOL
Dr Mercola Pure & Clear air purifier model# PC_AP2000. Unit stopped working, will not turn on. Cannot find a fuse in this unit. All else is in perfect working order. Thank you for your help.
The unit would be fused through the circuit breaker it gets power from in the main box of the house or in some cases a sub box to the main house circuit breaker box. If it is tripping the breaker something is seriously wrong and to reset over and over causes a fire risk, call a repair person.
Jan 24, 2017 | Heating & Cooling
LG LD450EAL no power
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
Jun 02, 2014 | LG Dehumidifiers
No power to wall unit
Have you tried plugging anything else in?
Also does the cord have a GFI breaker on it, or is the outlet a GFI outlet, if those are tripped it will keep power from going to the unit. If they tripped more then likely they got wet, or there is a short circuit.
Otherwise if all that is good circuit breaker would be next to check.
Aug 19, 2013 | Fujitsu Heating & Cooling
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Jenn-air built in refridgerator
Nothing not even the lights come on? A power surge might have blown out the breaker on the fridge.
Apr 04, 2012 | Jenn-Air Refrigerators
Fridge is causing the circuit breaker to trip when plugged in
Hi!!
Your unit is shorted out, check power cord and wiring on lower back of unit.
It may be the compressor shorted out.
If you have a pet, they some times remove wire insulation.
Turn unit so you can see the compressor housing on the bottom of the unit's back, you may need to emove the cover. turn breaker on and check if the small fan and the compressor kicked in. If the compressor did not start, and the breaker tripped again call a service tech to check unit.
Good Luck!!!
Aug 12, 2010 | Westinghouse Refrigerators
Roof top air conditioner wont stay on
Clean the condenser could be tripping on high pressure switch or low pressure switch low on freon have leak fixed and recharged. Tom
Jun 13, 2009 | Dometic Rooftop RV Air Conditioner
IS THERE AN INTERNAL BREAKER OR FUSE INSIDE A MAYTAG wc202
There is no fuse in this unit.
If unit has power but it is not cycling, then test wirings and circuit board.
Try first unplugging and plugging back the unit.
If there is no power at all , and the machine gives no sign of life, test the power cord and and the control assembly. In UK and other country there is also a fuse inside the power cord plug.
Here you find all diagrams and parts for your appliance <Click to open>.
Mar 15, 2009 | Dishwashers
Panasonic CW-C200NU Air Conditioner Logo
199 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
