A/c doesn't work-blows out hot air. last year took it to dealer and they recharged the a/c and put Freon in it but within a few months hot air was blowing out again.
The system will need to be recharged with freon and if there is no air flow in the front then there may be a stuck vent flap that won't move or a faulty motor that moves the flap.
More likely the recharge blew a o-ring and you have a leak. When your Cavalier was blowing hot air and a recharge fixed it that means it was low on freon which lets o-rings dry out, go back to the shop and have them leak test it. They use a pressurized dye to find the problem. If it's blowing it's not the cooling fan relay, they may have meant compressor relay but I'd have a leak test done first it's not expensive and easier that chasing unknown possibilities.
Hi
there.When a compressor is replaced,
two things are in fact being replaced - both the compressor and the refrigerant
(Freon) and if the problem is resolved as a result which of those two replaced elements
caused the original problem?Well you
will never know and so before the compressor is replaced you need to have you’re
A/C system recharged – it’s by far the most cost effective initial thing to do.In general A/C systems loose at least 10% of
their effectiveness each year through loss of refrigerant and so given the age
of your car; it’s the first thing to focus on.A professional A/C centre will also be able to tell you whether your
compressor is working properly after having a refrigerant recharge by the
monitoring the operating pressures in the A/C system.
You could need a recharge of freon or your A/C pump is bad. You can go to your local garage and have them recharge with an aftermaket freon kit or the dealer and have them put it on an a/c machine and really diagnose the problem
Unfortunately, the A/C systems on the GMT400 (92-99) GM SUV's were not particularly reliable. A fuse may have blown (unlikely), compresser may be bad, the condensor could be out, or the entire system may need replacement.
My advice? Take it to a different mechanic, or a dealer.
