If Clicking, then most likely the heater is looking for "Fuel" to ignite!
Also, ... if the heater is clicking, sparking, then the heater has received all the confirmation to ignite, no need to check for switch in ON position, or thermostat/heat setting up enough, or sensors or ??? If they had failed, then NO clicking! So again, it is now looking for fuel for main ignition.
check the gas valve, is it on?
check the main gas shut off, on?
When was last time the heater ignited? If recently just prior to non operation, then the gas valve had possibly failed? It is not opening to allow the main burner to ignite. do you have a flame at the pilot? If so, then all of the above checks are not necessary, hence if valves were off, NO flame at pilot assembly! If no Flame, then check the valves for gas supply.
My guess without being there to diagnose, bad gas valve.
The picture shows a Pentair Heater, this is the valve for that.
but they are all very similar.
