Question about Refrigerators
Not cooling after being off for 2 years
I have a fridgedaire refrigerator that was turned off for over 2 years. I turned it on - after 24hrs - freezer is blowing cold air - I don't get cool air coming to the fridge portion. Model # FRT183B4AWA. iS THERE A PROBLEM WITH LEAVING IT OFF FOR SO LONG - ANY QUICK AND EASY REPAIR?
  • 10,865 Answers
  • Is the thermostat knob turned to the proper setting? If not, reset it.
  • Next, see if the compressor motor is running
    The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
    • The compressor
    • The Thermostat
    • The overload, relay, or capacitor
    • The defrost timer
    • The condenser fan motor
    Posted on Jul 17, 2009
    Fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
    def sounds like a compressor issue/ sealed system issue, hopefully under 5 years old and you still have coverage
    Oct 27, 2008 | Kenmore 50522 / 50524 Side by Side...
    I have a fridgedaire refrigerator that isn't cooling in the fridge section but works well in the freezer. The model number is FRT1583AW6
    first check to see if freezer fan is running,then check to see if there is frost on back wall,then check to see if the duct going to the freezer has iced up.let me know-mike
    Jun 28, 2008 | Refrigerators
    Amana bottom freezer working fine but refrigerator not/ warm since 24hrs.
    There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
    Refrigerator2_bing.gif not Cooling or Fridge not Cooling
    http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
    How to Defrost Refrigerator Defrost Timer Problem
    http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
    heatman101
    Apr 28, 2008 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
    Refigerator leaked water slightly then stoped cooling
    Yes try to turn with a screw driver if possible. If it start working replace timer. If not it can be low on freon you would see frosting but no cooling.
    Jan 07, 2008 | Magic Chef CTF2125 Top Freezer...
    Refrigerator not cooling
    These units suffer from freezing up the evaporator in the freezer, before loooking for a fault I would suggest turning unit off for 24hrs leaving the door open, restart and within 24hrs the unit should work ok.
    Regards
    Advisor
    Nov 11, 2007 | Whirlpool GS6NBEXR Side by Side...
    Fridgedair side by side
    what to you mean by defrosted fridg. was frost built up in freezer>? check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, OR you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
    Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
    Refrig cooling
    check make sure all the fans are blowing one in freezer, one by compressor... should all be running when frig. is running
    Aug 30, 2007 | Refrigerators
    Fridge is hot while freezer works fine
    Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
    Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
    Frigidaire 7.5 cu.ft. Top Freezer the fridge part doesn't cool; freezer is fine.
    It should be under warranty, retry he is probably right, run for 24hrs and it should work ok, if you ever defrost you should turn off for 24hrs and leave the door open. Regards Advisor
    Aug 08, 2007 | Frigidaire GLRT83TES Top Freezer...
    Refrigerators Logo
    57 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
