Question about Kenmore 22422 Top Load Washer
Basket does not spin during rince cycle
I just replaced the lid switch and now the basket does not spin during rinse cycle . all other aspects seem to be working fine
    Genius:
  • 1,122 Answers
Does it drain/this will tell you if you did the lid switch correct-mike
Posted on Jul 17, 2009
Washing machine wont drain,rinse,spin,water wont drain out start a cycle but seems not to rinse,spin,drain
Could be a failed lid switch. This is a safety switch that shuts the machine off during cycles.
May 19, 2016 | Washing Machines
Maytag ensignia makes a great deal of noise during rinse cycle
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Whirpool model GSQ9669LW1 basket does not spin after replacing the broken coupler between motor and transmission. Motor showed good continuity using volt-owm meter on ohms setting on low, medium, and high...
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 06, 2017 | Whirlpool Washing Machines
LG washer won't move from the rinse cycle. Spins during the wash, but not in the rinse
If you have correctly selected rince and it doesnt rince, that part of the program is corrupt. Strangely enough, in S.Africa 90% of the washers with rince problems are the lg. Seen quite a few top loaders with this problem as well. There is no reason at all that once rince is selected it shouldnt work, except if faulty.. Only solution is to replace board if rincing to you is essential.
Sep 25, 2009 | LG WM-1832C Front Load Washer
Will not spin out or agitate during the washing cycle
DOES IT OPERATE IN THE RINCE CYCLE, IF NOT CHECK THE DOOR SWITCH. IF THIS IS A TOP LOADER THE SWITCH CAN BE PUSHED DOWN WITH A SMALL OBJECT WITH THE LID OPEN TRY THIS IF WORKING WHEN YOU DO THIS THE DOOR SWITCH NEEDS REPLACING
Aug 09, 2009 | GE Washing Machines
The Washer did not spin
MOR PROBELY THE CUPLER WENT OUT IS A 3 PEASE 2 WHITE AND 1 BLACK PART IN BUTTEM OF WASHR BETTEN THE MOTOR AND TRANMISION OR CK LID SWITCH. GOOD LUCK
Jul 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GEwdsr2080d top loading washer will not drain or spin
Yes, a magnetic lid switch and it is defective.
Replace it.
Mar 12, 2009 | GE Washing Machines
Roper washer frozen drive?
I would first check the lid switch and the plunger that pushes the lid switch. If both are good I would make sure the machine is washing properly. If the machine will not wash or spin you have a bad coupling. If the washer will wash then stop at the spin it is usually a bad lid switch, or transmission. The transmission will have a 5 year warranty. It is also possible that you have an object stuck under the main wash tub. You can remove the cabinet and look for objects or you can remove the wash basket itself. Good luck with your repair.
Mike
Sep 22, 2008 | Roper RAX7244KQ Top Load Washer
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore 22422 Top Load Washer Logo
105 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
