Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Picture has scattered "static" lines
That's the best way I can describe it...I have tried replacing the 3-way RCA jack, used a different input location, replaced the cable connectors to the wall plates...any ideas?
  • 4,402 Answers
Doe it look like these
Posted on Dec 05, 2007
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct fixya link:
Mar 13, 2011 | Pioneer VSX-D409
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
The VCR is playing and functioning, but the picture won't show up on the TV. I have all the channels set and it should be working, but the TV is the black and white static. Could it need dusted? It hasn't...
make sure the tv vcr button on the vcr is selected to vcr and that you have the tv on channel 3 or 4. try pushing the tv vcr button a few times back and forth on channel 3 then on 4. if that doesnt work try hooking the vcr up to the tv with the rca jacks. they will be yellow, white and red or maybe only two from the vcr yellow and white. hook them up the the correct input on the tv and change the input on the tv. if that doesnt work, your vcr may be done.
Dec 24, 2010 | RCA VR557 VHS VCR
No picture from monitor out on Onkyo TX-DS898
I realize you may have already doubled checked but make sure you follow this from the manual:
If the satellite tuner / cable box is equipped with an S video output
terminal, connect it to the S VIDEO 3 (or 4) IN terminal with an S
video cable. If it does not have an S video output terminal, connect
its video output terminal to the VIDEO 3 (or 4) IN terminal using an
RCA-type video connection cable. You do not need to connect to
both the S VIDEO 3 (or 4) IN and VIDEO 3 (or 4) IN terminals. If
the satellite tuner or television has component video outputs,
connect them to one of the COMPONENT VIDEO INPUT jacks.
With the initial settings of the TX-DS898, the VIDEO 3 and
VIDEO 4 input sources are set for the COMPONENT VIDEO
INPUT 2 jack.
If the video connection is made at COMPONENT VIDEO INPUT
1, this must be changed at the Setup menu: Input Setup → Video
Setup → Component Video (see page 35).
Using an RCA-type audio connection cable, connect the audio
output terminal on the satellite tuner or television to the same
VIDEO 3 (or 4) IN audio jacks on the TX-DS898. Make sure that
you properly connect the left channel to the L jack and the right
channel to the R jack.
If the device has a digital output jack as well, be sure to also connect
(OPTICAL) jack on the TX-DS898 depending on the device.
With the initial settings of the TX-DS898, the VIDEO 3 input source
is set for digital input at the OPTICAL 3 jack, and the VIDEO 4
input source is set for digital input at the OPTICAL 4 jack.
If the digital connection is made at a different jack, this must be changed
at the Setup menu: Input Setup → Digital Setup (see page 33).
Apr 15, 2009 | Onkyo TX-DS898 Receiver
Has sound but no picture
try a different rca cable, or even putting into a different input. Example, if you have dvd player hooked into input 2, and you have a input 3, try your connections there and see if you have the same problem. If so, use a different rca cable or whatever your cable maybe that you are using :-)
Apr 07, 2009 | Akai LCT3701AD 37 in. LCD Television
DTV hookup for an RCA XL-100
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
I dont know how to hook up a dvd player
Depending on the model of DVD player and the TV you are trying to connect it to you have various inputs and outputs.
If your have an HD (High Definition) DVD Player and a HD TV the best input to use is HDMI. Both device would have an HDMI interface whereby you could connect them together.
If you have a standard DVD Player you have usually 3 other input/output options, RCA, S-Video, and Component. Your RCA jacks are colored Red, Yellow, and White. Your S-Video is a larger circular jack with several pins. The Component cable has Red, Green, and Blue.
Of the three above the Component Cable connection is going to give you best picture quality. S-Video is second and RCA is third. You just need to match up the connectors on your TV and DVD and get the cable that accommodates the best picture quality. Again for clarification below are the interface options for best quality to poorest:
2. Component
3. S-Video
4. RCA
Hope this helps.
Jul 14, 2008 | Televison & Video
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
