Question about White Sewing White 3032
Bobbin area will not work
I have a old singer model 834 my mother in law just gave me i threaded the needle right but the bobbin area will not work at all i put the bobbin in pulled it threw the notches but i dont understand how it is supposed to work when the bobbin thread is no where near the needle , how can i get it to thread up threw i have no clue i have tried everything please help
    Brigadier General:
  • 4,088 Answers
There should be a spinning cover with a hook that fits over the bobbin. Normally, you just pull the bobbin thread out through the swinging/sliding plate hole. Turn the machine by hand toward you (at the top) until the needle dives into and comes back with both threads. Separate the threads and assuming that the thread tension above the needle is set correctly, feed a piece of material in to see if it sews correctly. The tension is set so that the thread is even on both sides of the material. Let the machine pull the material through at it's own pace, your function is to guide the material.
Posted on Jul 17, 2009
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
I have a singer 834 and I can't get the bobbin thread to come up. I have changed the needle and made sure it is in correctly
pull extra thread out and hold the end of it when turning the hand wheel .some will not pick up a loose thread .
Aug 22, 2015 | Singer Sewing Machines
Does any one know anything about a sewing machine model 217-APP no 457. Think it may be a singer, have just found it in late mother-in-laws shed. It won't pick up the bobbin thread but runs ok
not picking up the bobbin thread is an indication of needle / hook timing
thread tension problems appear as a mess of stitches under the cloth
the timing can be checked by having the needle full down and the hook of the bobbin case should be at the needle just above the eye of the needle
if it is too early or late then it is not in position to get the thread
May 13, 2015 | Sewing Machines
Singer model 7442 bobbin thread will not catch
have you tried changing the needle?
is the needle in backwards?
is the needle inserted all the way into the needle holder?
clean under needle plate & in the bobbin area for lint or loose thread
did you hit something with the needle?
Mar 03, 2012 | Singer 7422
I just got a new Singer Simple. I had a problem with the needle thread getting caught in the bobbin shuttle. I disassembled this area, found a random thread, and cleaned it out. I put it all back together...
Do you have the bobbin thread going the right way, according to owners manual some go clock wise some go counter clock wise when you pull the thread after bobbin inserted in bobbin case
Dec 27, 2010 | Singer 3116 Simple
I have an old singer sewing machine 401A. The top thread/needle won't pick up the bottom bobbin thread when it sews. What do I do?
You can download a manual for $10 at www.sewingmanuals.com and it should help you. A couple of suggestions though, is your needle inserted correctly? Flat side facing the rear of the machine, fresh needle? Threaded correctly on top and bobbin area? Is your thread good not too old and the same type in bobbin and top? Did you leave a long enough tail in the bobbin thread? 3-4 inches which you hold with your left hand. Is the thread in the bobbin unwinding the right way? Are you turning the handwheel towards you, not away from you at least two revolutions or until you see the thread loop? Try these suggestions, and I am sure one will work unless your timing is off and it needs professional service.
Sep 20, 2010 | Singer Sewing Machines
Hello I own a lovely old singer sewing machine,
Hi Mary! These old Singers are such wonderful machines! I'm always glad to hear from someone who loves them and uses them--they will last practically forever with very little ever going wrong.
Sounds like your upper tension is a little loose. I like to use different color threads on top and in the bobbin, to make the stitches easier to see. Also, are you using size 12 needles and 50 wt thread when you're adjusting the tension? Sometimes having a larger (or smaller) needle and/or thread can throw the tension off just a bit. Also, make sure the pressure foot is up when you're threading the machine but down when you adjust the tension and that you only adjust the tension in tiny increments.
You may need to adjust the bobbin tension--but that very seldom needs to be adjusted.
It's also possible that there's a bit of thread or lint caught in the tension disks or in the bobbin area.
Please let me know if these suggestions work.
Happy Sewing!
Robbie
May 12, 2010 | Singer 132QRFB Mechanical Sewing Machine
On my old Singer 834, the bobbin thread puts out
Are you sure the bobbin thread is in the case correct. it also as tension support.Or is the bobbin thread right . When you make your bobbins that also should have tension.
Aug 15, 2009 | Singer Sewing Machines
Was given an old model Singer 237 Fashion Mate with no manual. cannot get the bobbin to thread properly.
We'll here is a picture of what I need help on I need to know how to put the needle back along with the needle clamp screw
Jul 09, 2009 | Singer Sewing Machines
Needle will not go down and pick up bobbin thread
Check for a thread jam in the bobbincase. Lower looping is most commonly caused by a lack of top tension. Raise the presserfoot and rethread themachine again. Once threaded put down the presserfoot and pull the thread through the needle. if it pulls through easily it is still not threaded correctly. When threaded correctly the needle should bend but not break when you pull the thread through. good luck.
Jan 29, 2008 | Singer 1507
White Sewing White 3032 Logo
181 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
